I get this sometimes when i convert avi to vcd and i i split the audio from the video..What does this mean? How can u fix this?
Sounds like you got this while using TMPGEnc, if i'm right, then this usually happen when you have other programs running and one of them might be doing alot of CPU usage, and that usually bugs TMPGEnc.
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
Hi Sefy
What you'd want to do is open TMPG, go to the OPTIONS area, go to ENVIRONMENTAL SETTINGS, go to your VFAPI tab, and right click on the DirectShow media vfp. Increase it's priority till it opens your file. You'll be all set.~~~Spidey~~~
"Gonna find my time in Heaven, cause I did my time in Hell........I wasn't looking too good, but I was feeling real well......" - The Man - Keef Riffards
Starting Point
By NeptuneDrew in forum Video ConversionReplies: 10Last Post: 19th Jan 2011, 14:40 -
Help - invalid Floating point operation!!!!
By Pintocas in forum AudioReplies: 1Last Post: 15th Sep 2010, 09:28 -
r6002 floating point error with MPC , maybe
By BWMagus in forum Software PlayingReplies: 5Last Post: 19th Mar 2009, 08:08 -
MPC Runtime Error, 6002 floating point support not loaded.
By Leo99 in forum Software PlayingReplies: 5Last Post: 24th Nov 2008, 02:22 -
Point to point sharing with wifi adapter and wifi router?
By yoda313 in forum ComputerReplies: 5Last Post: 17th Jul 2008, 17:47
