I'm using mkv2vob to convert to vob for ps3. The audio is in AAC. For some reason mkv2vob will not convert it.
It saids "unsupported audio codec: A_AAC".
I want to convert the audio AC3, keeping the 5.1 in it. Is there a way to do that?
Latest version of avidemux can http://www.razorbyte.com.au/avidemux/
Open your video, when it says "do you want to use that mode..." say yes
Set video sidebar => Copy
Audio sidebar => AC3, configure your bitrate, filters or gain if you want. You may have to manually set mixer to 5.1
Format => MKV
Press save, include the extension (e.g. "myfile.mkv") -
Did not worked for me. The original audio was Russian. In Audio i set the option to add a separate English audio file, The max bitrate allowed was 384, I used if and set the mixer to 5.1. Program went to completion but the resulting file type is not MKV. In fact it has no suffix. Nero plays the original and does not allow for Audio change.
You didn't follow the instructions. You have to add the extension when entering the save as dialog "file.mkv". Also those instructions are for converting the audio, not adding in a separate audio track.Originally Posted by Wieinmeister
If you just want to add a separate track, an easier way for this is to use mkvtoolnix. Just open your .mkv, add the 2nd audio track, press merge. -
True, I forgot to write ".mkv" in the file name. Using the same method I got this time a playable file, But there was not any second audio track presentOriginally Posted by poisondeathray
However mkvtoolnix went just fine. Also the GUI is 10 times more smart than AVIDEMUX.
Thanks for your help
Can You Change The AR Flags in an MKV file?
By wulf109 in forum Blu-ray RippingReplies: 5Last Post: 6th Jul 2011, 19:00 -
Change audio in mkv from mp3 to ac3
By gauche in forum Newbie / General discussionsReplies: 2Last Post: 19th Jun 2011, 05:05 -
Recorded TS file change to 25fps instead of keeping it to 50fps in mkv.
By Dazzler1985 in forum Video ConversionReplies: 1Last Post: 18th Apr 2011, 17:01 -
Anyone know of something that will change audio sync in a TS or MKV file?
By Emanef in forum Video ConversionReplies: 2Last Post: 12th May 2009, 09:26 -
I have an MKV file, but when I change it to an m2ts file, the AR changes?
By anonymous99 in forum Video ConversionReplies: 22Last Post: 19th Jan 2009, 14:24
