Results 1 to 15 of 15
    Oct 2005
    Chicago
    I've ripped both sides of a dual sided disc and I'd like to combine them so that both sides are on one disc.
    Is there software that will allow me to combine the two ripped discs onto one?
    Dec 2003
    Eugene, Oregon
    Yes. Popcorn 3 has an option to do that easily as will the new Toast 9 when it is released in a few days. I suspect DVD2One has a feature for adding content from multiple VIDEO_TS folders as well.
    Oct 2005
    Chicago
    Any shareware that does it? DVD2OneX doesn't seem to be very intuitive.
  4. Member terryj's Avatar
    N35°25.24068, W097°34.204
    The following can combine VIDEO_TS folders into one DVD:
    Toast 9 will, Toast 8 can provided the rips are clean
    ( I have done three 1hr20min movies to one SL, and two 2hr+min
    movies to one DVD+DL)
    DVD2ONEX will also take ripped Video_TS folders and combine to
    one DVD (SL or DL). I did this with a FS and WS copy of the
    Incredibles, taking both Video _TS of each movie and combined
    them to play back to back ( FS to WS) for trips to Grandma's house.
    If the Main Features have been ripped and then the VOBs converted
    to Mpeg-2, then Visual Hub will join them onto one DVD.
    "Everyone has to learn, so that they can one day teach."
    When I'm not here, Where can I be found?
    Urban Mac User
    Oct 2005
    Chicago
    I tried it with DVD2OneX and it didn't give me an option as to which disc I wanted to view and it joined one track of disc one to the track on disc two. I'm joining my copy of Dr. Zhivago. It went from Omar Shariff's introduction to the intermission. So, it completely cut out Part One.
    What could I possibly be doing wrong?
  6. Member terryj's Avatar
    I assume that Dr. Zhivago is a Dual Layer disc, and that One Title
    is the main ( start credits to intermission) and one is the secondary
    (after intermission to end).
    If you first play it in DVD Player, what does it list as main title?
    as secondary title? Make a note of it, because that is what you
    need to join off in DVD2ONEX.
    So lets say that main title is Title 1 with 29 chapters.
    and that secondary title is Title 2 with 27 chapters.
    In DVD2ONEX, you would join each title one after the other,
    and check the seamless join box. Then the resulting disc,
    would playback T1 and T2 seamlessly on the disc.
    Now I assume that the disc is copy protection free.
    If not, you will rip each title to seperate folders FIRST
    using MTR, and then you will join those titles in DVD2ONEX.
    Urban Mac User
  7. Member twosocks's Avatar
    Jul 2003
    Right Here.....
    Here's an example of how to join a "flipper" (not the dolphin) disc.
    Maybe it will be of some help.
    http://www.2socks.org/Join_Both_Sides_of_a_Flipper_Disc.html
    Oct 2005
    Chicago
    That all works. What if I want all of the extras and commentary tracks?
    I'd love to find an option where it creates a menu at the beginning allowing you to choose which disc you watch. Then, upon selecting, brings up the menu of the disc that you choose.
    Jan 2006
    In other words, you want your cake and eat it too.
    Oct 2005
    Chicago
    I love cake. How do I bake some joined DVD cake?
    Dec 2003
    Eugene, Oregon
    A different approach is to extract each of the titles from the DVDs as MPEG files (you can do this with MPEG Streamclip) and use an application to author a new VIDEO_TS folder with a new menu pointing at each of those titles. I'd use Toast or Popcorn for this but you already have said you don't want to buy commercial software. For someone who wants so much you're making it hard on yourself by limiting your options this way.
    Oct 2005
    Chicago
    Ouch, man. I'm just trying to find out what's possible is all.
    I guess being inquisitive and trying to articulate what I want is a crime.
    If it can't be done, it can't be done. And apparently, I'm rubbing people the wrong way.
    Dec 2003
    Eugene, Oregon
    C'mon, you can't be that fragile. If you were rubbing me the wrong way I wouldn't have offered the alternative way of doing what you want. And I think it is fair to point out that the shareware limitation you were setting was narrowing your options.
    Oct 2005
    Chicago
    Blah.
    1) I stated exactly what I want at 10AM this morning. Authoring a new VIDEO_TS folder is obviously not an option that will get me what I previously stated that I want.
    2) Shareware was never a limitation. I asked about shareware and never said that it was a requirement.
  15. Member terryj's Avatar
    Since Shareware/low cost software isn't an issue,
    Then get DVD Studio Pro and you can do what
    you want to do easily.
    *shrugs*
    1. Rip the discs to the HD into folders by title, so you
    have a folder for Part 1,a folder for Part 2, a folder
    for extra 1, etc.
    2. Open up MpegStreamclip, ( w/QT Mpeg-2 addon)
    and demux each ttile into its elementary streams.
    ( m2v for video,ac3 for audio)
    3. Open up DVD Studio Pro, and author a new disc, create a new Menu
    and buttons to point to the assets on their own timelines,
    setting the navigation as you please.
    4. Burn the disc and your done.
    Urban Mac User
