Hi,
I am using Windows Vista and got JVC GR-D250 miniDV Camera. I am using 60minute miniDV tape.
When I connect it to the my laptop, it automatically ask me to import the video. Video is imported
successfully in .avi file format.
But its size is 12.6GB which is I think too large for one hour( 60 minute miniDV) tape.
Because three movies DVD which is 4 to 5 hours long can be in one DVD with good quality.
Is there any idea, I can reduce its size? At least upto 4.5GB so that it can be fit in one DVD.
Will it affect the quality( if it is affecting little bit which can not seen easily then its fine because this
is for personal use)?
Thanks,
Results 1 to 9 of 9
that is right size for DV.....DVD is not DV, it is MPEG 2, you need to get an encoder to encode to MPEG-2 and then a dvd authoring package to author the DVD....then burn with ImgBurn
'Do I look absolutely divine and regal, and yet at the same time very pretty and rather accessible?' - Queenie -
Thanks for reply,
Please let me know, "encoder to encode to MPEG-2" is software or hardware?
If software, is there any free software for that?
Is DVD authoring package, different than DVD burning software like "ImgBurn". If different please also let me know the free software for that.
Is free softwares are not available, please let me know which softwares are good for this, so that I can buy it.
Thanks, -
Two I use pretty frequently are DVDAuthorgui and GUIfordvdauthor.Originally Posted by ron spencer
HI.. you can use Virtualdub and framserv the video to HC encoder via a small .avs script.Originally Posted by prayami
In this can also be done with other video formats. Virtualdub is a VERY powerful videoeditor.
Install Panasonic DV codec, Virtualdub, Avisynth and Hc encoder (use V0.21 v0.22 have some issues).
The audio must be converted to .mpa (mpeg2) or .ac3 (Dolby Digital) use Qenc for this.
How to frameserv and create the .avs script do a search in the site.
BUT if you dont want to have FULL control on every step use DVD flick, nice program
stars....
Imported home MiniDV movies into iMovie 09, but now I've upgraded to FCE
By ctakim in forum MacReplies: 0Last Post: 14th Jan 2011, 23:17 -
Convert AVI (miniDV) to MKV/MP4, large files only convert partially
By Video Eddie in forum Video ConversionReplies: 0Last Post: 3rd Jan 2011, 06:44 -
Deinterlacing MiniDV AVI file and saving as lossless AVI
By Dave2ic in forum Video ConversionReplies: 3Last Post: 27th Dec 2010, 16:11 -
ffmpeg choppy audio from large avi but not small avi source file
By cybertheque in forum Capturing and VCRReplies: 9Last Post: 13th Oct 2008, 16:38 -
Avi file too large for CD
By hitmanhill in forum Newbie / General discussionsReplies: 17Last Post: 22nd Jan 2008, 15:19
