hi folks..
ok i'm really stuck.. evry time i try to burn a disk i get errors.. i've tried a couple of different disc types and they all fail (apart from a dvdrw i tried!?)
anyway, i've recently reinstalled windows, coz i had a bug & reinstalled my progs..
here is the log from nero (which means nothing to me....)
any help would be great!! thanks.. brushuk
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Nero\Nero 7\Core\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 02/11/2004 13:54:32
NT-SPTI used
Nero Version: 7.0.0.0
Recorder: <DVDRW IDE1008> Version: 0052 - HA 1 TA 0 - 7.0.0.0
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ?
CD-ROM: <DVDRW IDE1008 >Version: 0052 - HA 1 TA 0 - 7.0.0.0
=== Scsi-Device-Map ===
DiskPeripheral : WDC WD400EB-00CPF0 atapi Port 0 ID 0 DMA: On
DiskPeripheral : Maxtor 6Y120L0 atapi Port 0 ID 1 DMA: On
CdRomPeripheral : DVDRW IDE1008 atapi Port 1 ID 0 DMA: Off
CdRomPeripheral : SONY CD-RW CRX215E1 atapi Port 1 ID 1 DMA: Off
=== CDRom-Device-Map ===
DVDRW IDE1008 E: CDRom0
SONY CD-RW CRX215E1 F: CDRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 74448896 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 511MB (523760kB)
Free physical memory: 45MB (46628kB)
Memory in use : 91 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
13.3.2008
UDF/ISO compilation
12:13:14 #1 Phase 112 File dlgbrnst.cpp, Line 1724
DVD-Video files reallocation started
12:13:14 #2 Phase 114 File dlgbrnst.cpp, Line 1724
DVD-Video files reallocation completed (no file modified)
12:13:15 #3 Text 0 File Isodoc.cpp, Line 6410
UDF document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
UDF Mode : UDF/ISO bridge
UDF Revision : 1.02
UDF Partition Type : physical
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet :FALSE
Allow pathdepth more than 8 directories : FALSE
Allow more than 255 characters in path : FALSE
Write ISO9660 ;1 file extensions : TRUE
12:13:15 #4 Phase 111 File dlgbrnst.cpp, Line 1724
DVD-Video files sorted
12:13:15 #5 Text 0 File ThreadedTransfer.cpp, Line 525
ReadBuffer-Pipe got 262144KB of Memory
12:13:15 #6 Text 0 File Reader.cpp, Line 124
Reader running
12:13:15 #7 Text 0 File Writer.cpp, Line 113
Writer E: DVDRW IDE1008 running
12:13:15 #8 ISO9660GEN -11 File Geniso.cpp, Line 3304
First writeable address = 0 (0x00000000)
12:13:15 #9 ISO9660GEN -11 File Geniso.cpp, Line 3304
12:13:15 #10 Text 0 File Burncd.cpp, Line 3301
Turn on Disc-At-Once, using DVD media
12:14:15 #11 Text 0 File DlgWaitCD.cpp, Line 277
Last possible write address on media: 2298495 (510:46.45, 4489MB)
Last address to be written: 993663 (220:48.63, 1940MB)
12:14:15 #12 Text 0 File DlgWaitCD.cpp, Line 289
Write in overburning mode: NO (enabled: CD)
12:14:15 #13 Text 0 File DlgWaitCD.cpp, Line 2568
Recorder: DVDRW IDE1008, Media type: DVD-R
Disc Manufacturer: UME01 -
Disc Application Code: 64, Disc Physical Code: 193
12:14:15 #14 Text 0 File DlgWaitCD.cpp, Line 456
>>> Protocol of DlgWaitCD activities: <<<
Insert empty disc to write to.
(Medium in drive: Unknown. Medium required by compilation: DVD+R/RW, DVD-R/RW.)
12:14:15 #15 Text 0 File ThreadedTransferInterface.cpp, Line 846
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 993664 (993664) = #993664/220:48.64
relocatable, disc pos for caching/writing not required/ required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 993664 blocks [E: DVDRW IDE1008]
12:14:16 #16 Text 0 File ThreadedTransferInterface.cpp, Line 1058
Prepare recorder [E: DVDRW IDE1008] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 2035023872, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep_______ ___
0 | lead-in | 0 | 0x41 | 0x00
0 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
993664 | lead-out | 1 | 0x41 | 0x00
12:14:16 #17 Text 0 File SCSIPassThrough.cpp, Line 34
SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME
12:14:17 #18 Phase 24 File dlgbrnst.cpp, Line 1724
Caching of files started
12:14:17 #19 Text 0 File Burncd.cpp, Line 4129
Cache writing successful.
12:14:17 #20 Phase 25 File dlgbrnst.cpp, Line 1724
Caching of files completed
12:14:17 #21 Phase 36 File dlgbrnst.cpp, Line 1724
Burn process started at 4x (5,540 KB/s)
12:14:18 #22 Text 0 File ThreadedTransferInterface.cpp, Line 2669
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
12:14:18 #23 Text 0 File DVDR.cpp, Line 2469
Recording mode: Sequential Recording Mode
12:14:18 #24 Text 0 File MMC.cpp, Line 21541
Set BUFE: Super Link -> ON
12:14:19 #25 Text 0 File DVDR.cpp, Line 2624
Start write address at LBA 0
DVD high compatibility mode: Yes
12:14:19 #26 Text 0 File Cdrdrv.cpp, Line 8385
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 2.0x (5), Extended Part Version: 0.0 (0)
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 0 h
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Data in Burst Cutting Area (BCA) does not exist
Start sector number of the current Border-Out: 0 h
Start sector number of the next Border-In: 0 h
Media Specific [16..63]:
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
12:14:45 #27 Text 0 File Cdrdrv.cpp, Line 1195
12:14:45.109 - E: DVDRW IDE1008 : Queue again later
12:21:25 #28 SPTI -1135 File SCSIPassThrough.cpp, Line 306
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1135)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 00 00 06 7D C0 00 00 20 00 00 00
Sense Area: 0x71 00 03 00 00 00 00 0A 00 00 00 00 0C
Buffer x04cf0000: Len x10000
0x00 00 01 BA 44 6C DE E4 96 2D 01 89 C3 F8 00 00
0x01 E0 07 EC 81 00 00 18 48 60 63 15 86 77 03 92
0x13 C6 23 B0 00 D4 0E 40 27 41 5C 6E C5 67 DB 84
12:21:25 #29 CDR -1135 File Writer.cpp, Line 302
Write error
E: DVDRW IDE1008
12:21:26 #30 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
12:21:27 #31 Text 0 File ThreadedTransfer.cpp, Line 222
conversion idle, stopping reader
12:21:28 #32 Text 0 File DVDR.cpp, Line 2866
EndDAO: Last written address was 425407
12:21:39 #33 Phase 38 File dlgbrnst.cpp, Line 1724
Burn process failed at 4x (5,540 KB/s)
Existing drivers:
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
brushuk,
The burn problem is almost certainly being caused either by your burning drive not being in DMA mode, or the inferior media you used. The first thing you should do is get the drive into DMA mode. Here's how to do that (ignore the part that applies to the Primary IDE controller, as yours is already using DMA...just do the Secondary IDE controller):Right click on [My Computer] and select [Properties] from the menu. Click [Device Manager] on the [Hardware] tab, then click to open the [IDE ATA/ATAPI (hard disk) controllers] section. You will find: the Primary IDE Channel controller, Secondary IDE Channel controller. Complete the following procedure:
1. Right click on the Primary IDE controller and select [Properties] from the menu.
2. Select the [Advanced Settings] tab. Check that the [Transfer Mode] for both devices is set to [DMA if available].
3. Repeat this for Secondary IDE controller.
It probably isn't a factor in this instance, but your Iomega drive is using version 0052 firmware. This page at the Iomega website has version 0060 available for your "DVDRW IDE1008" drive. The newer firmware is likely to work better with newer media.
Since this was your first post here, welcome to VideoHelp. -
If you still have problems after using VegasBud's suggestions, you might want to use a recent build of Nero. Your version (Nero Version: 7.0.0.0) had many many bugs. Another option would be to use imgburn (free)
Also make sure that you are not doing anything (like surfing or playing games, multitasking) while burning, because if your system specs are correct, 512MB system ram might cause you experience buffer underruns even with the "nero buffer"
Problems burning AVCHD w/Nero & IMGBurn...
By girlcreeture in forum Authoring (Blu-ray)Replies: 7Last Post: 3rd Sep 2011, 10:31 -
Errors burning movie to BD-R using HP bd340i burner & PowerProducer softwar
By BDNov in forum Authoring (Blu-ray)Replies: 1Last Post: 15th Feb 2011, 08:34 -
svcd preview errors & vob file errors
By kiwi76 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 10th Nov 2008, 16:02 -
Nero failure burning "Audio & Data cd"
By spiritgumm in forum AudioReplies: 4Last Post: 15th Oct 2008, 16:25 -
spumux & dvdauthor. No errors, but no subs either
By bepaald in forum LinuxReplies: 5Last Post: 29th Mar 2008, 15:54
