I'm lookin to buy a laptop and found a nice toshiba laptop with HD DVD, but was wandering if there any point buying one if the HD format lost to BLU RAY? Is is better to wait, buy a cheaper laptop without HD or will the HD format stick around??? Thnx
Why you would want to watch HD anything on a laptop is beyond me. No benefit on the small screen.
You can connect it to a 100" Plasma...
I would probably wait for a blu-ray if you want to play HD movies. -
HD-DVD players are being cleared below $100. If I wanted HD-DVD on a 100" plasma that's what I'd buy. Its lower than incremental cost on a Toshiba laptop with HD-DVD vs DVD.
I really would not want to use S-video or VGA to drive the 100" plasma either. Thats the available outputs on the Toshibas I checked. -
I'm just asking if there is a point in buying a laptop with an HD DVD drive if the format lost with BLU RAY.. will HD DVD most likely become useless in a while???
No sense buying it. They will not be making any more HD DVDs, so unless you have an extensive HD library and you watch all your movies on a laptop, it isn't worth an extra dime. Frankly, on a 15" screen you won't notice any difference than regular DVDs.
I love children, girl children... about 16-40
W.C. Fields -
Wouldn't a DVD writer be more useful?
http://www.kiva.org/about -
http://www.buy.com/retail/product.asp?sku=207562527&adid=17654&dcaid=17654
Optical Drive Blu-ray ROM with SuperMulti DVD Burning
1x HDMI
$999.99
Need advice on purchasing a new DVD recorder.
By MOTUfan in forum DVD & Blu-ray RecordersReplies: 25Last Post: 21st Apr 2009, 12:40 -
Purchasing new dvd recorder vcr combo - wanting to copy pay per view
By rbusenbark in forum DVD & Blu-ray PlayersReplies: 3Last Post: 18th Jun 2008, 16:27 -
DVD burner performance in HP laptops
By qpskfec in forum DVD & Blu-ray WritersReplies: 3Last Post: 3rd Dec 2007, 18:47 -
Purchasing DVD Fab HD or Platinum ?
By MacPCConsultants in forum DVD RippingReplies: 3Last Post: 2nd Dec 2007, 00:21 -
Purchasing Mac.
By serega in forum MacReplies: 12Last Post: 6th Nov 2007, 09:25
