Hi, I'm trying to add new subtitles to a dvd.
I was wondering if there is a way to find out the font, size, colors, styling, outline... of the original subtitles?
I think the color part is the easiest, and I tried to copy the color using the Open palette option in SubtitleCreator but the outline color wasn't the same as on the original subtitles so the new ones turned out to be really hard to read...
Use DVDsubedit to change colours.Originally Posted by jujuandhuhu
You can change each of the 3 or 4 colours used separately (fill, outline, background).
You can edit individual subs, then do "Edit/Apply last change to all". -
You can try to use WhatTheFont to determine which font was used.
In the beginning the Universe was created. This has made a lot of people very angry and been widely regarded as a bad move. -
But, if I understand correctly, there is no way to find out the complete formating of the original subtitles?
For example by converting them into text? -
Not really. The subtitles are stored as images. It is not possible to convert them to text, what you can do is to OCR them to text (Optical Character Recognition). That means that the software you use tries to identify letters in the images (=subtitles) and what you get is unformatted, raw text.
No, as träskmannen says, that will just give you an ASCII file.Originally Posted by jujuandhuhu
Make some screencaps and crop to the subtitle and try WhatTheFont. It's often right.
There is also a forum you can appeal to there if the automatic recognition fails.
Far too many subtitles just use Arial or ArialNarrow, awful as they are.
I think just because they start with A and become the default.
There is a lot of info about subtitling fonts at http://screenfont.ca/
I mostly use either Verdana or Lucida Fax.
original DVD subtitles Help
By cavusozkan in forum Authoring (DVD)Replies: 5Last Post: 29th May 2010, 16:18 -
How to add Subtitles to original DVD whitout loosing original subtitles ?
By Chainsaw_1 in forum Newbie / General discussionsReplies: 2Last Post: 6th Jan 2010, 13:52 -
Copy subtitle formatting?
By zf1223 in forum SubtitleReplies: 2Last Post: 27th Dec 2009, 23:14 -
Added subtitles to a dvd but want cant seem to get the original menu workin
By Loonatik in forum Authoring (DVD)Replies: 8Last Post: 9th May 2008, 06:31 -
Can I copy an original DVD to VCD?
By cxgcxg in forum Newbie / General discussionsReplies: 4Last Post: 31st Mar 2008, 05:50
