Actually my goal is to display the dvd instead of my webcam in msn using Camtasi recorder capture==>output==>live but i keep getting black screen!!
I tried to play the dvd with both vlc and medial player but both gave me black screen!!
So for the test purpose i tried to record but i still get black video!!
Did you try disable overlay in vlc? Under Settings->Preference->Video and untick Video overlay.
You can disable overlay/accerelation in windows media player under Tools->Options->Performance->Hardware acceleration. -
I ran into this problem earlier today trying to use Snagit to capture a corrupt MKV movie off of Media Player 6.4 that I can't get any editors to either open or save the whole file. I knew it was an overlay problem but I couldn't find a way to solve it. After hours of googling, I finally found the answer from the Snagit website.
They said to turn off hardware acceleration in media player and...
under Settings > Control Panel > Display > Settings > Advanved > Troubleshooting, to turn Hardware Acceleration off. I turned it down to the third setting which disables direct draw and 3D acceleration. Use this setting to correct severe problems with DirectX accelerated applications and now I can capture from media player.
EDIT: I tried unticking the overlay in VLC Player but it didn't work but after turning down hardware acceleration under Display, it now captures from all my media players. -
Two other ways to kill overlay...On the 'Video' tab(s) of DxDiag there's a checkbox that'll do it...or...Since 'Overlay' can only be used by one program at a time, open two instances of your video player and the second one won't be using overlay.
Can someone tell me how the VLC player's recorder works?
By gastrof in forum Newbie / General discussionsReplies: 7Last Post: 3rd Apr 2014, 03:17 -
Stream Recording with VLC - Black frames problem
By Kittciokas in forum Video Streaming DownloadingReplies: 6Last Post: 7th Aug 2011, 08:38 -
Camtasia Studio recorder
By photon_ed in forum Video Streaming DownloadingReplies: 1Last Post: 14th May 2008, 11:00 -
having a problem with vlc player
By king vitamin in forum Video ConversionReplies: 8Last Post: 8th Aug 2007, 19:15 -
problem recording from windows media player 11 using camtasia
By method in forum Newbie / General discussionsReplies: 0Last Post: 27th May 2007, 15:42
