I am building an HTPC and I will need a hardware MPEG2 encoder card. I also require Linux compatibility. This is sort of a cloudy question, but is there any difference between the rock solid PVR-350 and the dual tuner PVR-500MCE? And I what I mean is, is the PVR-500 basically the same hardware just with two tuners? I want the same excellent quality and Linux support for this new card that already exists for the PVR-350. Thanks.
Darryl
(Mods, if you feel that this topic better fits in the Linux forum, then please move it)
No not same hardware the 500 has newer chip set and dosen't run hot like the PVR 350 dose
Hauppauge PVR-350 periodical audio distortion
By frankvnk in forum Capturing and VCRReplies: 1Last Post: 2nd Oct 2010, 09:40 -
Setup Hauppauge WinTV PVR-350
By DaveQB in forum LinuxReplies: 9Last Post: 18th Oct 2009, 23:56 -
A Better Way To Run a PVR-350?
By hech54 in forum Capturing and VCRReplies: 0Last Post: 30th Jun 2009, 00:56 -
PVR-350 Problems
By nealf in forum Capturing and VCRReplies: 23Last Post: 26th Nov 2008, 23:47 -
Considering Hauppauge WinTV PVR 350...
By chewie8008 in forum Capturing and VCRReplies: 9Last Post: 2nd Oct 2007, 18:20
