Hi, I was wondering if anyone can help me? I have a bunch of .flv videos that I want to convert into .avi or any other format that supports DVD players so that I can watch them on my DVD player.
Thanks for any help
(BTW, I searched arround and found nothing that can help me)
use the perian plug in for QT and save as mov files, from there you can use mpeg2works, ffmpeg, or visualhub to convert to mpeg2 files...what kind of work do you do in kuwait?
I use SUPER. It works great without any trouble. I can even batch process multiple .flv videos at once.
why not cut out the middle man and use VisualHub period?
Open Visualhub, select the .avi tab,
drag and drop you .flvs into the bottom window,
click convert.
If you need to do it through Quicktime, Perian is a Codec for
Quicktime, that enables the Quicktime Player Pro* to open .flv files
and play or transcode them to other formats, such as .avi.
So with Perian 1.1 installed, Open Quicktime Player Pro.
Then go File-->Open and select the first .flv file.
Then go to File-->Export, and select .avi file as the choice,
and then if necessary, fine tweak the selection, choosing
the codecs for audio and video.( I reccommend Apple-Photo Jpeg-A
for video, and AIF 16bit for video.) Then click ok, and then save
to the Hard Drive. Quicktime Player Pro will transcode the
file properly using Perian 1.1.
( *Note: You'll need to have bought the Quicktime Pro upgrade for this
Player to upgrade to Pro status, and thus be able to transcode
files from one format to another.)"Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User
Remux FLV (AVI and MP3) to AVI without VFW?
By vbug in forum Video ConversionReplies: 2Last Post: 26th Mar 2010, 12:32 -
.FLV vs. .AVI
By coody in forum Authoring (DVD)Replies: 8Last Post: 19th Mar 2010, 20:20 -
Movie Clip Will Not Convert from .flv to .avi - Pazera Free FLV to AVI
By videoelfone in forum Video ConversionReplies: 3Last Post: 21st Jun 2008, 00:14 -
Problem with artifacts in flv conversion - i.e. converting to flv from avi
By brassplyer in forum Video Streaming DownloadingReplies: 9Last Post: 30th Apr 2008, 22:09 -
Mux a FLV AVI + MP3 -> FLV with ffmpeg or mencoder?
By Colmino in forum Video ConversionReplies: 9Last Post: 29th Mar 2008, 22:11
