I have several avi's on my pc. Whenever I click directly on an avi in Windows explorer I get the error messages as indicated in the images attached.
I can only play them IF I launch VLC and open them through there.
My codecs are kept up to date as are my patches/updates, etc.
Can anyone offer advice or a solution to make this crazy behaviour stop?
Thank you.
Most likely the xvid codec is crashing when Windows Explorer uses it to get a thumbnail image.
It's quite common when the codec contains a bug that causes it to tell Explorer that it can do something that it can't.
Have you checked to see if there is a more recent version of the codec?John Miller -
I have in the past but not in the past couple of months. I'll do that now. I wonder if I should just overwrite it or rename the old dll first....
Thanks Johnny ... I appreciate your input. -
Just in case, rename the existing one before putting a new one in the same location.
Great. That would be my choice too. I'll let you know how it turns out.
Thanks again
Audio synch problems on an .avi file -noob
By ComicFan2 in forum ffmpegX general discussionReplies: 4Last Post: 18th Dec 2008, 12:47 -
File conversion problems AVI to Divx
By kaptainm in forum ffmpegX general discussionReplies: 2Last Post: 10th Aug 2008, 19:21 -
Question about Windows error msg and high cpu when right clicking on avi
By jimdagys in forum ComputerReplies: 3Last Post: 4th May 2008, 17:01 -
AVI file problems.
By wicked_pix in forum Newbie / General discussionsReplies: 9Last Post: 5th Dec 2007, 10:27 -
Having problems compressing AVI file
By nucklhead24 in forum Newbie / General discussionsReplies: 6Last Post: 17th May 2007, 22:42
