I have some HD MPEG2 recorded on DVD. I think I saw a post here that one way is to use a Xbox. My HDTV has only component input for HD. Can somebody tell me the configuration in simplest terms? Thanks.
I would search or ask in http://forums.xbox-scene.com/index.php
The simplest way is that if your HDTV can act as a PC monitor (most if not all can do this) then just take your PC and connect it to the HDTV using the HDTV as your monitor. There are a variety of programs that can play HD content on a PC. I recommend VLC if you need something. The Xbox can play HD content, but I think you may have to do some converting to get it to work. You'll need to check with Xbox experts on that. WMV at 720p is known to work.
This is what I'm talking about but I could not find that postOriginally Posted by jman98
I wonder if I will record the MWV on DVD or play it on PC which is more difficult for me to do. Thanks, anyway.
Thank you Baldrick for that link.
Old films to high definition?
By therock003 in forum RestorationReplies: 39Last Post: 1st Jan 2015, 09:27 -
High definition DVD
By rene-rottingham in forum Newbie / General discussionsReplies: 13Last Post: 21st May 2010, 07:35 -
High definition conversion
By kypreo in forum Video ConversionReplies: 10Last Post: 21st Mar 2010, 23:15 -
High Definition on DVD
By Dem Pyros in forum Authoring (Blu-ray)Replies: 24Last Post: 2nd Sep 2008, 09:48 -
video 8 to high definition
By devdev in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 10th Jan 2008, 14:31
