I use mac. How can I play avi video with sub file ? The subtitle is sub file, so it is hard to find way to show sub file. I tried VLC, but it didn't work
You could convert the subs to .srt format and VLC should see them if they're in the same folder as the AVI. One Mac program for that: http://mac.softpedia.com/get/Video/Sub2Srt.shtml
Did you try manually loading them?
File => Open File => Checkmark use subtitles file (browse and open the main video file, and subtitle file) -
To open my files with subtitles I think VLC would be your best option. Does anyone know a program that can actually imbed the subtitles into the AVI file?
Problems with display of File / Preferences
By Lehmeier in forum Newbie / General discussionsReplies: 7Last Post: 12th Aug 2011, 06:06 -
How To Display REAL File Sizes?
By VideoNoobz in forum MacReplies: 8Last Post: 2nd Mar 2010, 16:59 -
Display subtitles inside a divx file
By renzord in forum SubtitleReplies: 8Last Post: 2nd Nov 2008, 13:46 -
choose the appropiate codec for display an AVI File in Windows OS
By htamayo in forum Newbie / General discussionsReplies: 3Last Post: 20th Jun 2008, 15:33 -
Pioneer DV-410V File DIsplay Question
By olegeiser in forum DVD & Blu-ray PlayersReplies: 2Last Post: 13th Jun 2008, 14:19
