Results 1 to 14 of 14
    Dec 2005
    Im looking for a decent program that can capture streamed video.Im using cam studio at the moment but the quality is not so good.
    I use firefox together with the download helper plugin and also orbit downloader. It works for most streams.
    Dec 2005
    Thanks,does it capture video from windows media player 11.Basically just want to capture the movie and put it onto dvd or stream to my xbox,if i could get tversity to work.
    Dec 2005
    Tried orbit and it dosent work but im using sdp downloader and get the error message,resolving dns ip address then tccp socket connect failed 10060?
  5. Member Seeker47's Avatar
    Jul 2005
    Some sites do a good job of concealing the correct URL that you need. Perhaps you need something like URL Snooper ?
    Looking for Rare / Obscure / Hard-to-Find Films ? Check out http://rarefilmm.com/ , and also its Requests & Discussion forum http://rarefilmm.chatango.com
  6. Member zoobie's Avatar
    Feb 2005
    Florida
    sdp?
    try baldricks suggestion with firefox's plugin
    Dec 2005
    Where do you get the download plugin? also off subject,does anyone know how to get tversity to work with the xbox 360? see several posts on the subject but dont fancy uninstalling all my codecs.
  8. I'm a MEGA Super Moderator Baldrick's Avatar
    https://addons.mozilla.org/en-US/firefox/addon/3006 (first hit on google... )
    And what problems do you have with tversity? I installed and it worked fine directly on my xbox360. Start reading http://tversity.com/support/ .
    Dec 2005
    Thanks, im not sure if tversity is recognizing the xbox! how would i know? i can only play certain video types on the xbox and im using windows media player 11,does tversity transcode any video file for the xbox?
    Dec 2005
    Cool,followed the guide and now its working fine,thanks.
    Dec 2005
    New problem,now trying to get, you tube videos to work using orbit or the firefox plugin,they download,no picture just audio?
    Dec 2005
    There coming up as flv videos? someone explain please
    Mar 2008
    815, United States
