Hi All,
Not sure if this is the right section or not.
I'm taking MPEG2 files, captured OTA, and using Avisynth/WMNicEnc to encode to VC-1, with the intention of using TSMuxer and TSremuxer to create blu-ray folders to burn to DVD+R. After encoding I end up with a WMV file, which plays fine with windows media player, but TSMuxer doesn't recognize the VC-1 stream. I used Mplayer to strip out the raw video stream but TSMuxer still doesn't recognize the stream.
Is there some simple step I'm missing?
TIA
Brian
	TSmuxer 1.4.6 says it supports VC-1 video.
 Use ASF2VC1 for getting a compliant elementary stream from an ASF container.
 { http://www.ftyps.com/unrelated/asf2vc1/ }
	Well Midzuki, ASF2VC1 seems to be the step I was missing. Although for some reason after I extract the stream, TSMuxer thinks the frame rate is 23.97, instead of 29.97. But that's easy to fix with TSMuxer. I'm encoding a 45 minute clip right now so I expect to know sometime tonight how it looks playing in my bluray player.
 Much Thanks
 Brian
	Okay, I have discovered TSremux assumes every 29.97fps video is
 "necessarily" a 23.976fps video with pulldown flags --- which is a bad feature
 if you happen to be dealing with a progressive 29.97fps source (the resulting
 m2ts file will become a macroblock festival when played back ) )
 The safe choice is to run asf2vc1.exe with the option "-nfrm" and then
 input the correct framerate in the TSmuxerGUI window. Good-luck!
	Hmmm, that's interseting.
 Initially I let TSmuxer just let it go with 23.97, even though I specified 29.97 when encoding. After muxing the m2ts I played it in PowerDVD ultra and it played back jerky. Not a random jerking, but almost like a strobe effect. I muxed it again with TSmuxer set to 29.97 and it played fine in PowerDVD.
 I'll try the "-nfrm" option.
 I did mux a 720p movie last week with TSmuxer, but TSMuxer had correctly identified it as 29.97fps. But when played back it was showing a similar jerking. I was assuming it was to high a bitrate for the DVD+R discs or my Samsuck BD-P1200 player, or both. That was an MPEG2 file.
 Again, you're very helpful, thanks
 Brian
  Help with multiple .m2ts files to one .m2tsBy neworldman in forum Blu-ray RippingReplies: 10Last Post: 4th Sep 2013, 11:16
  Video Re-Muxing Problem: How to Re-Mux to M2TS?By WellBeSerious12 in forum Video ConversionReplies: 5Last Post: 15th Sep 2011, 03:31
  mux m2ts to m2ts with AC3 audio without reencoding the videoBy BirdDaddie in forum Video ConversionReplies: 3Last Post: 22nd Aug 2010, 22:19
  MKV avc to m2ts via tsMuxer;1080p muxing problem for ps3. PleaseBy rafoolik in forum Blu-ray RippingReplies: 5Last Post: 11th Aug 2009, 18:55
  shrink .m2ts to smaller .m2tsBy inano in forum Blu-ray RippingReplies: 2Last Post: 14th Jan 2009, 09:50
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
