I've been reading a lot of forums about these things but I don't think I'm getting any clear answers. Based on my understanding about each setting is it correct for me to assume that these rules apply for the following situations:
VBR Bias
The lower the bitrate the lower the bias? By lowering the bias, it'll help distribute bits from less demanding areas to highly demanding areas. Or more simply, a bias of 20 or less for bitrates less than 3000, about 20-25 for average bitrates of 3000-4500, and a 25-30 bias for higher bitrates of 5000 and up. Although I've read posts that suggest a higher bias of about 25 for lower bitrates but I don't see how this works.
Quality Precision
I've read that with bitrates of 3000 or more, this can be set to about 28-34 and this seems to hold true for all things I've done. And for lower bitrates, a quality precision of about 20-24.
So far a VBR Bias of 15 and Quality Precision of 28 with a multipass of 4 (1+3) has looked great for all movies I've encoded. Despite what my eyes perceive, however, all I want is assurance that these general rules apply for those certain situations and that I'm understanding the settings correctly. I know this type of thread may seem redundant, but I just need some clarification.
I'm not trying to look for the 'best' or the 'optimal' values for the settings as I know each movie differs from one to another. There's no one best setting, not one that fits everything. All I want to know is if my understanding of it is correct. An encode may look good in my eyes but really bothers me is the fact that maybe I could've done better had I fully grasped the concept of VBR Bias and Quality Precision.
as far as the bias goes, if the bitrate is under 3000 there just aren't enough bits to redistribute no matter how low you go. there comes a point of deminishing returns. the lower you set the bias the more passes cce needs to move the bits around. i've gone as many as 9+1 passes on marginal material. on normal dv to mpeg-2, set it in the middle and don't worry about it and 3+1 is fine for passes. same with QP if you have decent source video it just won't matter as long as it's not set at the fringe.
So I guess it's the other way around: the lower the bitrate, the higher the bias? The only problems I've had encoding were with movies that last around 3 hours or more. I'm thinking of splitting most of them but for some I want to keep in one DVDR. These movies run under 3000 and without not enough bits to throw around, should I try for a more CBR finish? Perhaps a bias of 25-30 or more?
And what about high bitrate movies? Since there are more bits to redistributed, would I be right to say that a lower bias (15-20) would make a better encode verses a higher bias (25-30)?
AviDemux 2.5 beta motion precision settings change?
By MilesAhead in forum Video ConversionReplies: 0Last Post: 14th Jun 2009, 16:30 -
CCE SP2 number of VBR passes
By DRP in forum Video ConversionReplies: 1Last Post: 25th Oct 2008, 03:53 -
TMPGEnc advanced settings for best quality results
By tdavid232 in forum Video ConversionReplies: 1Last Post: 15th May 2008, 19:02 -
vbr passes in cce 2.70 sp
By DSLGuy in forum Video ConversionReplies: 1Last Post: 20th Feb 2008, 00:33 -
Best Advanced CCE Settings in DVD Rebuilder
By devnulllore in forum Newbie / General discussionsReplies: 1Last Post: 16th Jul 2007, 12:56
