I have a movie that is 700mb, its a Mpeg Layer 3 file, and I want to be able to watch it on a DVD player so what I did was I converted it with CovertXtoDVD but I get a problem that I never got before when I try to burn it and here it is:
After I put a regular DVD+r or -r in the tray it tells me I need double layer dvd+r or dvd-r... does anyone know why that is? I used to always be able to burn the dvds on regular dvds... thank you for your help in advance.
Results 1 to 12 of 12
Settings => Encoding => Target Size DVD-5 (4400MB)
I'm guessing you had it set on DVD-9 (8200MB) -
What version of convertxtodvd are you using?
What software are you using to burn? convertxtodvd? nero or something else?
Check the size of the Video_TS folder authored by convertxtodvd, how big is it? -
Sometimes the resulting video can come out larger than intended. It's probably oversized but I would guess it isn't insanely so.
the video ts total file size is 4.30 gb so i dont understand why its asking for dual layer it doesnt make sense.
Software ? If you use the wrong software - something like NeroVision, for instance, it may try to re-encode your video and will make it larger int he process.
Read my blog here.
no im using convertxtodvd... what do you mean ? thanks for your help btw
Double-sided, double-layer. Are they the same thing?
By ibzomie in forum MediaReplies: 8Last Post: 5th Feb 2011, 17:13 -
Burning Double Layer DVD with no Layer Break.
By aspen matthews in forum Authoring (DVD)Replies: 12Last Post: 24th Oct 2009, 14:26 -
DVD+R9 Double Layer first burn: problems with layer switch
By Edmund Blackadder in forum DVD RippingReplies: 400Last Post: 4th Oct 2009, 12:27 -
Need to burn my first double layer dvd EVER.... HELP !!!
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 20Last Post: 25th Mar 2009, 17:42 -
Double Layer DVD
By nagihcim1 in forum Newbie / General discussionsReplies: 1Last Post: 7th Sep 2007, 20:09
