Results 1 to 11 of 11
  1. Member kippard's Avatar
    Dec 2005
    Looking for a Quad Core at least 2.8 GHz, 2GB of RAM and 2x 750GB hard drives - how cheap can I get it? Where? Options and opinions appreciated!
  2. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    It's not gonna be cheap unless you build your own computer. Here's one I found that you can configure at Dell. It does give you the xp pro reinstallation cd.
    http://configure.us.dell.com/dellstore/config.aspx?c=us&cs=19&l=en&oc=DXCWCF5&s=dhs
  3. Member kippard's Avatar
    Dec 2005
    Thanks. Where would you go about buying to build? I bought a bare-bone and drives for my current PC - is there a deeper level of build-your-own?
  4. That dell is a 2.4 GHz Q6600. If you really want 2.8+ GHz you're looking at Xeon processors. 2.83 GHz Xeons start around $700 just for the CPU. They'll usually come on a server class motherboard that will cost big bucks too.
  5. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    Just buy the components from online retailers like Newegg.com and build it yourself.
    You can always overclock that Intel Quad core cpu to 3.00ghz if you build the computer yourself.
  6. Member kippard's Avatar
    Dec 2005
    Thank you! What do you suggest, if I want to max out the board I have? I saw System Information for Windows to determine my RAM options - any good? How about determining what processor I can upgrade to? Looking for the cheapest way to doable HDV, and maybe my board can do it.
  7. Mod Neophyte redwudz's Avatar
    USA
    http://www.newegg.com/Product/Product.aspx?Item=N82E16819115017
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813128083
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820145034
    http://www.newegg.com/Product/Product.aspx?Item=N82E16822136131 X 2
    That comes to about $780US. Throw in a good graphics card, a couple of optical drives, a case, power supply, keyboard and mouse, close to $1000US in parts, not including a monitor and tax and shipping.
    If your present computer is as shown in your specs, up the RAM to 1GB, add a second hard drive. That would be the easiest improvement. I don't know which Athlon that is. Unless it's a AM2, you are a bit limited for upgrades. You can go to your motherboard manufacturer and see what other CPUs are available for your motherboard.
  8. Member Soopafresh's Avatar
    Jan 2004
    redwudz - that motherboard is nice. Did you see the number of USB and Firewire connectors? Handy.
  9. Mod Neophyte redwudz's Avatar
    USA
    I liked the 8 SATA ports and the S/PDIF coaxial and optical out .
  10. Member kippard's Avatar
    Dec 2005
    Is a 7200RPM video only drive enough for HDV editing? Thanks!
  11. Member Soopafresh's Avatar
    Jan 2004
    Yes, for what you're doing. The important thing is to read from one drive and write to the other. That's why 2 drives work pretty well with video editing.
