  1. Is it possible to creat buttons on a menu using TSCV?
    Example, rather than have to press 1, 2 , 3, etc to select titles or chapters, can I set up a menu that will allow you to move the "cursor" around on the menu and press enter? So that you can move up and down through the options with the remove control?
    I know that you can in the Phillips program, but I'm new to the TSCV prog and cant see where you could possibly do this.
    regards
    Cargodog
  2. Member adam's Avatar
    Sep 2000
    Those type of buttons are not supported in either the vcd or svcd standard. You can do this using cdi functions on your vcd but they will only work on a cdi player.
    You can simulate this function however. Create a series of stills with the buttons drawn over the items to be selected. Have the next and previous buttons work like directional buttons, scrolling through the various stills and have the enter button linked to the appropriate item.
  3. Thanks Adam! I will give that a try.
    Cargodog
