Two questions for the price of one!
I have a bunch of WMV clips on my hd and would like to convert them to a format to play on my home DVD player. I though I had found what I was looking for with Roxio Easy Media Creator 10, but it won't install on my Viata OS for some reason. I keep getting a message that the installation is interrupted. So, how can I convert WMV to DVD, and ? is there a known problem w/Easy Media Creator 10 and VIsta? Thanks. -John in San Antonio
Well, my method uses AviSynth to frameserve to my MPEG-2 encoder (TMPGEnc Plus), but I'm sure there are easier methods. I think ConvertXtoDVD will handle converting WMV to DVD-video.
Also, you can search the "Tools" section in the left menu by what conversion you want by using the drop-down menu, and find a selection of tools for that task. -
WMV is a PITA to convert. I've succeded by loading the WMV in MovieMaker, and save out as DV AVI, then encode the DV AVI to mpg.
/Mats
has any one had trouble installing roxio easy vhs to dvd 3
By dirtfarmer in forum Capturing and VCRReplies: 0Last Post: 1st May 2012, 00:04 -
Easy DVD Creator by Ether Software
By DW49 in forum Authoring (DVD)Replies: 4Last Post: 30th Dec 2007, 15:33 -
How do I get Roxio Easy Media Creator to Do What I Used to Do With Nero?
By AlleyCatty in forum Authoring (DVD)Replies: 0Last Post: 20th Nov 2007, 16:27 -
Roxio Easy Media Creator 10 verses Pinnacle Studio 11
By snuggels in forum Newbie / General discussionsReplies: 3Last Post: 3rd Oct 2007, 13:10 -
Roxio Launches Easy Media Creator 10
By roxann in forum Latest Video NewsReplies: 0Last Post: 5th Sep 2007, 16:27
