Objective:
Add hard subtitles to ripped HD-DVD and convert to BD.
The conversion part from HD to BD without re-encoding is relatively straigtforward but I run into problems with remuxing a txt file subtitle into a BD stream.
The other way around is to hard sub and then re-encode to VC1 before re-muxing to BD.
So, is there a hard sub script for avisynth that accepts txt files and can I re-encode to VC1 using megui?
Regards,
Rob -
I don't think megui can encode to VC1; only x264, XVID, snow, LMP4Originally Posted by rhegedus
You can use WMNicEnc to create an ASF/WMV file and
then extract its VC-1 stream with ASF2VC1.
{ http://www.ftyps.com/unrelated/asf2vc1/ } -
Thanks for the info guys.
I'm a bit new to avisynth so I haven't had a chance to play around that much.
I tried the script:
..but get no success.DirectShowSource("D:\HD-DVD_EDITS\BOURNE_ULTIMATUM\BLU-RAY\BDMV\STREAM\00001.m2ts",fps=23.9760431376968,a udio=false)
#TextSub("D:\HD-DVD_EDITS\BOURNE_ULTIMATUM\EDIT.srt")
What should the script read in terms of source text file?Regards,
Rob
Uncoupling subtitles? / Subbing problem on VLC?
By elvenbunny in forum SubtitleReplies: 1Last Post: 5th Feb 2012, 04:26 -
Hard subbing .ass subtitles and keeping font usage?
By Yuusui in forum MacReplies: 2Last Post: 18th Nov 2010, 09:38 -
Hard Subbing with popular Video Converters
By jcj487 in forum Video ConversionReplies: 1Last Post: 23rd Aug 2010, 05:17 -
Dropsies-What's the worst you've dropped a hard drive onto a hard surface
By Seeker47 in forum ComputerReplies: 6Last Post: 11th Jun 2008, 13:53 -
hard disc 1 died, hard disk 2 won't boot, halp!
By Yoroshiku in forum ComputerReplies: 6Last Post: 30th Oct 2007, 14:48
