Every time I try to uninstall any programs, wheter it's via the Add/Remove Programs dialog or if I use the uninstall.exe for the specific program/folder, I get the same error -- cannot find INSTALL.LOG.
Apparently this is a Windows system file that has somehow been deleted.
Any ideas on how I can uninstall applications now?
I've got over 20GB of music on the compute, so a reformat and OS installation would really not be preferred.
TIA!
"To steal ideas from one person is plagiarism; to steal from many is research." - Steven Wright
"Megalomaniacal, and harder than the rest!" -
when you run cleaners, sometimes it deletes this file
you can try reinstalling these programs which will remake the install.log then try to delete them -
that's kinda what I thought.
what a PITA..."To steal ideas from one person is plagiarism; to steal from many is research." - Steven Wright
This should help. http://support.microsoft.com/kb/290301
I've used it in the past when there was a uninstall problem. What I do if the program will not uninstall nor re-install is use this utilty to cleanup the install for that program. Then I can install and uninstall.
Good Luck
Description of the Windows Installer CleanUp Utility
SUMMARY
Microsoft has updated the Windows Installer CleanUp Utility. With the Windows Installer CleanUp Utility, you can remove a program's Windows Installer configuration information. You may want to remove the Windows Installer configuration information for your program if you experience installation (Setup) problems. For example, you may have to remove a program's Windows Installer configuration information if you have installation problems when you try to add (or remove) a component of your program that was not included when you first installed your program.
The Windows Installer CleanUp Utility does not perform the following functions: • Remove Windows Installer
• Remove files of any programs that are installed by Windows Installer, such as Microsoft Office 2003
The Windows Installer CleanUp Utility does perform the following functions: • Provides a dialog box in which you can select one or more programs that were installed by Windows Installer
To do this, select the programs that you want in the Installed Products list in the Windows Installer CleanUp dialog box. After you make this selection, the utility removes only the Windows Installer configuration information that is related to those programs.
• Removes the files and registry settings that make up the Windows Installer configuration information for programs that you select
If you use this utility
Timing issue with different programs.
By Jon.G in forum Authoring (DVD)Replies: 1Last Post: 15th Nov 2010, 02:35 -
Is it possible to remove subtitles from one dvd and add them to another?
By nouseforaname in forum EditingReplies: 2Last Post: 16th Jul 2010, 15:54 -
Programs to Remove/Suppress ugly WARNING screen in this W.C. Fields classic
By MISS CHIEVOUS in forum EditingReplies: 13Last Post: 28th Jun 2010, 16:03 -
Add/remove sub idx to/from vob
By ystiang in forum SubtitleReplies: 6Last Post: 8th Jun 2010, 22:50 -
How to add and remove audio stream?
By albo23 in forum EditingReplies: 3Last Post: 1st Jan 2009, 09:54
