I have several .avi files and i wish to put them onto several DVD-R's to play on my DVD player.
Problem is i wrote a few to a DVD-R and put it in my DVD player and they came up unknown.
Questions:
1. What format do they have to be in to work on a DVD player?
2. What (free)software would i need to do this, and how?
I also have a MAC so no windows guides please.
THANKS!
1. DVD-Video, www.videohelp.com/dvd#tech
2. I don't know. Moving you to our MAC section. -
so the .AVI's have to be converted to MPEG1 or MPEG2?
(MPEG2>MPEG1?) -
If your player doesn't play AVIs, they have to be reencoded to mpg2, and authored as DVD, yes.
The free software (any) market for Macs is pretty limited. Toast is a commercial offering, but then, a player that plays AVI is cheaper.
/Mats -
Open source solution: Burn (that's its name). May be found here:
http://www.versiontracker.com/dyn/moreinfo/macosx/30120
Edit: Burn doesn't create proper UDF volumes. I tried a DVD Burn had created in my Samsung DVD player (which is somewhat picky); it reported that the disc wasn't able to be loaded. Burning with Toast or Burnz (note the "z") yields compatible DVDs. Burnz is excellent software for about $12.50. Burnz may be found here:
http://www.thinkertons.com/ -
"Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User
Good Up-converting DVD Player under $100
By wulf109 in forum DVD & Blu-ray PlayersReplies: 4Last Post: 8th May 2011, 12:02 -
Found DVD/AVI software player that displays Chinese srt subtitles with avi
By jimdagys in forum Software PlayingReplies: 1Last Post: 14th Nov 2009, 20:45 -
Vidego28 - Converting avi for portable player
By jangelj in forum Portable VideoReplies: 3Last Post: 10th Feb 2008, 19:05 -
Converting AVI to DVD, but jumps on my dvd player.
By memphis12 in forum Video ConversionReplies: 11Last Post: 19th Oct 2007, 06:25 -
Create Root menu for avi's on DVD without converting each avi?
By Ghtpua in forum Authoring (DVD)Replies: 2Last Post: 8th Sep 2007, 00:23
