Im having trouble converting vhs to dvd.I have a Archos player that I hook up to my vcr and record onto and the file would be a avi file.Then I would convert the avi file to vob file with convertXtodvd and then use Nero to burn it.They come out pixilated and the dubbing is off.Is there another program I can use to convert the avi file so that the dubbing is good?Any help would be appreciated.
Sean
If you are really serious about transferring VHS to DVD, I would suggest using a DVD Recorder standalone, a PC capture card, or a DV Bridge. They should give much better results. You don't want to capture, compress with mpeg4, and then compress to mpeg-2.
If your only option is the Archos, then a higher quality solution would be:
Use AviSynth to frameserve into HC and encode to MPEG-2.
Export the audio as a WAV from the avi using VirtualDub.
Compress the audio with tooLame.
Use MuxMan to author.
Burn with ImgBurn.
The above is all free software. -
Thanks Vidd,thats all greek to me but im gonna try it sunday.
Sean -
Can you be more specific ? Which mathod is better ?Originally Posted by Vidd
What kind of standalone DVD recorder ? DV bridge ? -
I would prefer a DV bridge and it could be a canopus advc110 its about 200-300 EUR.
You connect the VHS, video8 or what ever to the box and the picture and sound will be converted
to DV format in real time, well you must have a firewire connection in you computer.
The source will approx have approx 25Mbit/s, and it will not get better than this.
The source will be in a .avi container and can be edited with Virutaldub.
you can use windv , dvio or microsofts movie maker to capture the movie. windv is prefered.
Panasonic dv codec must be installed to open the .avi file in virtualdub..
well this is only the begining....
do a search on the site...
stars....
Should I use S-VHS cable for standard VHS transfer?
By Gibson's Squares in forum Newbie / General discussionsReplies: 11Last Post: 16th Feb 2012, 13:50 -
I need help! Audio cleaning on vhs transfer to DVD
By GoggleboxUK in forum Newbie / General discussionsReplies: 21Last Post: 12th Apr 2010, 22:44 -
cant transfer,to dvd, old family vhs movies i had professionaly made
By axememan in forum Newbie / General discussionsReplies: 1Last Post: 19th Sep 2009, 09:33 -
Tracking problems on old VHS, trying to transfer to DVD
By bingobanjo in forum RestorationReplies: 16Last Post: 13th Feb 2009, 17:40 -
How to get DVD Quality on a VHS Transfer?
By Nitro89 in forum Capturing and VCRReplies: 28Last Post: 10th Nov 2007, 01:26
