Hi there, I'm using FCP6.0.2. I've made a rough cut and I'm simply trying to burn this straight onto DVD using DVDSP4. I know I have to export the file as a Quicktime movie but get lost after that... if anyone could point me in the direction of a quick star guide that would be absolutely amazing!
Much much appreciated.
Let me get this straight...you want to learn how to author a DVD but your complaining because the manual for DVDSP goes into too much detail on how this is done? Not to sound like a jerk but we've all been in your situation....and have read the manual too.
Google it
http://www.google.com/search?hl=en&client=firefox-a&channel=s&rls=org.mozilla%3Aen-US%...ls&btnG=Search -
Our new motto around here should be:
"If you can't be bothered to read the manual, don't bother us."
A lot of what we are going to tell you is in the manual my friend.
suffice to say, I'll give you one hint:
Don't export to QT movie, export to Compressor instead,
and then select the Mpeg-2 encoding preset to match the length of the
finalized FCP project......"Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User
Vegas movie studio 11 -- need to burn AVCHD file to DVD
By malcolm1 in forum Newbie / General discussionsReplies: 14Last Post: 8th Nov 2011, 03:12 -
Final Cut Pro: Converting FCP formatted .MOV to PC compatible format
By 6079 in forum Video ConversionReplies: 6Last Post: 23rd Sep 2010, 09:29 -
FCP: What is the best way to work with .m2v files in a FCP timeline?
By murraymile in forum MacReplies: 1Last Post: 23rd Jan 2009, 16:59 -
Final Cut Studio 2 vs. FC Express
By JediPM in forum EditingReplies: 5Last Post: 24th Feb 2008, 17:00 -
Suggestions - where to buy FCP studio 2
By Russ1 in forum MacReplies: 1Last Post: 11th Oct 2007, 10:32
