Hey please move this post to the appropriate forum as I was not sure where to post it thanks. My question is about Imtoo dvd creator and play times.
If I add 3 mpegs to the program to burn on a blank dvd of 4.7 gb/ 120 minutes, and the total size/time after conversion is just under 4.6gb/180 minutes, will this dvd have playing issues since it surpasses the 120 minutes mark capable of the blank dvd? Or will they play just fine but perhaps I will lose quality?
DVDs don't have a set amount of playing time. It depends on the bitrate they are encoded with. But they do have a set size of about 4.37GB. Some programs read that as 4.7GB, just bad math.
Bitrate is determined by the playing time of all videos combined vs the size of the media used. As a 'rule of thumb', one hour per DVD is best quality, 2 hours is good, more and the quality decreases fairly rapidly. But quality is also dependent on source quality.
You might try a bitrate calculator from our tools, like the VideoHelp Bitrate calculator to see what bitrate you will end up with. You can check the bitrate of your burned discs by using Gspot on one of the VOBs.
You might also take a look at 'WHAT IS' DVD to the upper left on this page for the DVD specifications, format and structure.
ImToo DVD Ripper problem
By -phenom- in forum DVD RippingReplies: 2Last Post: 9th Aug 2010, 10:52 -
ImTOO DVD Ripper Platinum Works Well but Would Like Smaller Files...
By w6rlf in forum Video ConversionReplies: 2Last Post: 18th May 2009, 12:30 -
ImTOO DVD Ripper, can't rip my DVD's!!!
By Hashum in forum DVD RippingReplies: 20Last Post: 11th Oct 2007, 08:35 -
Ripping Audio with ImTOO DVD Ripper Platinum 4 vs DVD Audio Extractor
By xtreme469 in forum AudioReplies: 0Last Post: 29th Sep 2007, 03:06 -
IMTOO ripping prob
By sealclubber666 in forum DVD RippingReplies: 3Last Post: 20th Sep 2007, 13:05
