Hi there, I have many DVD-Rs which I have used to record TV shows, ads etc from the telly. I want to be able to
1. Play them on my laptop -its an Acer Aspire 5100 running WindowsXP.
2. Rip from them so I can play separate clips as mpegs.
I'm totally confused as to what codec I would need to play these DVDs. I've always assumed that I can play these DVDs on my laptop. I normally use Windows Media Player, but have other players installed such as Quicktime, VLC, Realplayer etc.
Any help would be very greatfully received!
You need a Directshow MPEG 2 decoder. You may also need to finalize your DVD-R media in the DVD recorder before your computer can read it properly.
Yes, s-video connectors have 4 pins. The connector on the ATI cards have more. The extra pins carry component video.
That isn't an ATI card's DIN output but it should give you the idea. -
Hi there, just wanted to say thanks for all your help. I worked out that the problem was the DVD -R was not finalised - had to work out how to finalise it on my Samsung VR-320 and now it plays on my PC! Hey presto!
Thanks all.
Playing dvds recorded fron tapes on a Sansui dvd recorder, on a LG RH399H
By Eric2011 in forum Video ConversionReplies: 11Last Post: 6th Jul 2011, 05:56 -
Recorded DVD won't play in my laptop
By vpanganiban in forum Software PlayingReplies: 7Last Post: 12th Dec 2008, 03:53 -
Standalone recorded DVD playing in a Mac problem
By tigerdad in forum MacReplies: 4Last Post: 5th Aug 2008, 21:28 -
[SOLVED] Playing recorded DVDs on the computer (Samsung DVD-SH853)
By ToniVC in forum DVD & Blu-ray RecordersReplies: 4Last Post: 16th Nov 2007, 14:59 -
DVD Recorded discs won't play on Laptop!! ):
By SteveMKIIDub in forum Software PlayingReplies: 11Last Post: 21st May 2007, 18:24
