What is the difference between 720x480 (4:3) and 720x480 (16:9) ??
Reason I ask is ? When I convert a 720x480 (4:3) video to 16:9, the movie looks exactly the same on my monitor.
Why does 320x240 convert to 352x240 look exactly the same on my monitor, shouldn't 352x240 be wider at 4:3 ratio ?? Such as when TMPGEnc, converts those resolutions. I'm confused. Thanks for any help.
Results 1 to 13 of 13
Magician's trick
It is all about SAR, PAR and DAR vs. square pixels.
Do your research. Truly all is illusion.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
PAR = Pixel Aspect Ratio
SAR = Storage Aspect Ratio
DAR = Display Aspect Ratio
They can all be different.Recommends: Kiva.org - Loans that change lives.
A flag in the file that tells the player what aspect ratio to display the video at.Originally Posted by Illusionist
This can take the form of a Diplay Aspect Ratio (DAR, the shape of the final picture) or a Pixel Aspect Ratio (PAR, the shape of individual pixels).
DAR = SAR * PAR
Where SAR is the Storate Aspect Ratio, or relative frame dimensions. -
For example assuming square pixel display and storage at 704x480 with NTSC 4:3 PAR of 0.9091,
704 * 0.9091 = 640
So square pixel 4:3 display would be 640x480.
NTSC 16:9 PAR is 1.2121
704 * 1.2121 = ~854
So square pixel 16:9 display would be 854x480.
If a 16:9 display had a full screen 1366x768 square pixel rsolution, both horizontal and vertical woul be upscaled 1.6x to fill the screen.
But if a 16:9 display had a full screen 1024x768 resolution (DAR = 0.75), then vertical would be scaled 1.6x but horizontal would be scaled
854 * 1.6 * 0.75 = ~1024Recommends: Kiva.org - Loans that change lives.
Or more directly:Originally Posted by edDV
SAR = 704/480 = 1.4667
PAR = 0.9091
DAR = SAR * PAR = 1.4667 * 0.9091 = 1.333 -
can someone tell me what side do i need to get to transform 640x480 1:1 ntsc to 16:9 with out that "fat" look, i guess croppin or addin borders but ¿how much?
640x480 square pixel to 16:9 DVD:
1) Crop 60 lines off top, 60 lines off bottom (or a total of 120 lines, however many top and bottom), resize the remaining 640x360 to 720x480 (NTSC) or 720x576 (PAL).
-- or --
2) Resize to 540x480 (NTSC) or 540x576 (PAL), add 90 pixel wide borders left and right to bring the file back up to 720 pixels wide.
You can use a program like FitCD to get more precise numbers and numbers for other sizes. -
thanks jagabo
can u tell me if i addborders left n right do i see black lines on left n right when playin on dvd or only the widescreen ones? -
No it won't. It will give you a 4:3 image in a 16:9 frame. I didn't mean it as two steps, but rather two different ways. I edited the post to make it clearer.Originally Posted by guns1inger
