I'm trying to convert a mkv to a mp4 to play on my xbox 360. I used gotsent (i have all the codecs) to convert a mkv file and the files it generated were a .mp4 file that is only 1 kb big and a movie.h264 file that is 2,000,000 kb big. When i try to open the mp4 file i get an error message. Am I doing something wrong here or is there something else i should be doing.
Thanks in advance![]()
Results 1 to 15 of 15
Thanks for the quick reply. Not too sure what to give you with media info but this is what i saw...
First video stream:
english, 8028 Kbps, 1280* 528 at 23.976 fps, AVC (Main@L5.1) (CABAC)
First audio stream:
640 Kbps, 48 KHz, 6 channels, AC3 -
Are you using the newest beta version?
There are other approaches as well. Ripbot264 works using the "console" profile.
You can also manually do it using this guide http://www.afterdawn.com/guides/archive/how_to_play_mkv_content_on_xbox_360.cfm
You have to make the format compatible with xbox 360, it's finicky on what file types it will accept
http://blogs.msdn.com/xboxteam/archive/2007/05/09/spring-07-video-playback-faq.aspx
Good Luck -
thanks for the info. Man theres a lot involved in this. What ever happened to just clicking covert and everything working flawlessly.....
I got a question. GOTsent converts my .mkv file perfctly to a .mp4. Now i wanna play it on my 360, so i change the extension to .wmv, burn it as a data disc then put it in my xbox. Now the problem is my xbox doesnt play it. It reads that its there, but beside the name there is a red circle with a line going across it. Ive played already converted mp4's on it before so its not the system. I think im missing something when im converting, mybe a codec. Do you know what i am doing wrong?
Thanks! -
MP4s aren't the same thing as WMVs. Are you saying you've renamed .mp4 files to .wmv in the past and the 360 had no problems playing them? Does the 360 play .mp4 files directly?
If cameras add ten pounds, why would people want to eat them? -
Yes. Ive downloaded Superbad in mp4, changed it to .wmv and it played on my 360. I changed it cuz i read that XBOX only plays wmv and not mp4. mp4 is for PS3, although i havent tried burning a mp4 directly and playing it. Maybe i will and ill see what happens!
It does say AVC, which is synonymous with H.264, and it being level 5.1 it's highly likely it's x264 since that's its default setting.Originally Posted by AbondI hate VHS. I always did.
I've never tried GOTSent since I don't encode for an XBox. But upon reading its description, it doesn't re-encode the MKV file.
There may be the problem right there - MP4 natively doesn't support AC3 audio (at least not without a "hack"). You would have to re-encode the audio to something like AAC (I'm assuming the H.264 video stream is XBox 360 compatible.)
You can demux the H.264 video stream using MKVExtract, then mux it with the encoded AAC stream into MP4 using MP4Box.I hate VHS. I always did. -
Sorry i've been away from my post for awhile and thanks for the replys. To get you guys up to date, I've tried converting my file with gotsent again and this time i got working mp4 files..somewhat... I got 3 files this time, the first one was fine, the second one had the first's video but the sound continued from the first part, and the third was the same as the seconds. Wierd...Still no luck converting this file. Just so everyone knows, what i'm trying to do is play hd videos from my xbox 360 without the buffering. I can play my mkv file through tversity but it always buffers and the video quality suffers. If anyone else has any suggestions, i would be glad to hear them.
Obviously gotsent isn't working for you.
Did you try the guide posted above? Manually doing it isn't that hard and there are screenshots to guide you.
Even if you successfully muxed into an .mp4 (with converted ac3 => aac audio) you will find that your xbox360 doesn't support the video you originally referred to, because the video was encoded with AVC Level 5.1 profile according to the mediainfo you posted. Xbox only supports 4.1. Translation: you have to re-encode your video. gotsent doesn't re-encode video.
Don't forget xbox only supports 2 channel aac (not 5.1 sound)
All this information was posted in the links I posted above.
If you want an easy way to convert your video use ripbot264. Use the "console" profile for AVC Level 4.1. Make sure you specify 2-channel aac audio. Note you will lose some audio quality and video quality because you are re-encoding both with a lossy format.
Good Luck
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 12:19 -
mkv to xvid using Gotsent
By c1steady in forum Video ConversionReplies: 4Last Post: 3rd Dec 2009, 04:49 -
Are there are other apps like gotsent? Looking to convert mkv to mp4
By AndyD in forum Video ConversionReplies: 42Last Post: 8th Sep 2009, 07:09 -
Fixing audio sync issues when using GOTSent to convert MKV to MP4
By darrklight1138 in forum Newbie / General discussionsReplies: 1Last Post: 20th Apr 2009, 07:56 -
Gotsent producing mp4 with audio only
By sidneysides2000 in forum Video ConversionReplies: 2Last Post: 11th Jan 2009, 18:10
