Video from my HDR-HC1 appers choppy when there is fast movement in the video. The video is stright from the camcorder in .m2t file not even compressed yet. Any ideas? Ive used powerdvd and media player classic and they both show it.
It can't be my PC i built its a
Q6600 OC to 3.2ghz quad core
4GB of 1066 RAM
eVga 8800GTX
The video was captured by firewire using HDV Split.
If the HC1 plays back smoothly connected directly to the TV then it probably isn't a problem with the file. To be certain, transfer the file back to the camcorder and play it from there.
The problem is with the computer even though it has great specs. Do other HD MPeg2 or MPeg4 files play smoothly Maybe Power DVD (or other MPeg decoder) isn't installed properly.
Try VLC. It has its own MPeg2 decoder.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Check out the deinterlace modes (try "mean" or "linear") and the excellent screen cap under video. The screen cap respects the deinterlacer settings. Use "bob" for full a resolution 1080i motion cap. It will interpolate 1440x540 to 1440x1080. "Discard" will cap a field to 960x540.Originally Posted by David97Recommends: Kiva.org - Loans that change lives.
Camcorder: buy 1080i or 1080p? Final Cut Express only does 1080i
By adrien23 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 13Last Post: 12th Nov 2010, 06:37 -
editing mp4 1080i files, audio not synced, video choppy
By headros in forum EditingReplies: 3Last Post: 24th Apr 2010, 15:22 -
Can't figure what's wrong with this 1080i video
By adessio in forum Video ConversionReplies: 24Last Post: 28th Feb 2010, 21:23 -
1080i video now what?
By David97 in forum Video ConversionReplies: 1Last Post: 23rd Feb 2008, 13:40 -
Is 1080i thru Component the same video quality as 1080i thru HDMI?
By Denvers Dawgs in forum DVB / IPTVReplies: 27Last Post: 13th Jul 2007, 17:25
