Iam sending back my Toshiba SD-370E as on odd occasion it freezes for a fraction of a second and has lost sound twice in two weeks ive had it - this seems to happen mostly on DivX files....
Can anyone recommend a budget DivX HDMI 1080p upconverting DVD Player?
I was going to get the PHILIPS DVP5980 for £50 as my dad says it ranked no.2 in which magazines top 50
too me features arent important, what i want is:-
Excellent Upconversion of SD to HD
DivX Playback
USB slot (optional)
unless anyone can convince me otherwise i think the DVP5980 is the one
http://www.amazon.co.uk/gp/product/B000Q7ZCO6/ref=olp_product_details?ie=UTF8&me=&seller=
THANKS
Results 1 to 9 of 9
Oppo's, http://oppodigital.com , players are considered the best by most. But they cost US$170 or more. The philips players like the 5960 (1080i) and 5982 (1080p) are pretty good. Some people like the Pioneer DV-400V-K.
what is difference between the Philips DVP5980 (that i want) and the DVP5982 (I cant get in UK)...?Originally Posted by jagabo
Could it be that your Toshiba is just fine, and that there is a problem with the divx files? I have an Oppo, and even it will get confused by a badly corrupted file, although it usually ploughs through anything.
no, the DIvX files are fine have tested them on laptop, PC and other DivX DVD player - its just done it tonight on another DivX file - also when it does it the sound is out of sync for the rest of video by the amount of time it froze/skipped.... it actually done it 3 times tonight.
its doing to frequent now - nearly every divX file i play its doing it on... the SD370-E is starting to get a bad reputation for it now - over 60% of reviews i read say the same... look on Amazon -
Have you checked the Toshiba site for the latest firmware? Try that before you return the player. Toshiba usually has a very good rep.
I love children, girl children... about 16-40
W.C. Fields -
For upconverting I bought a Toshiba HD-A3,it's an HD player but I will use it for upconverting SD DVD's. I paid $83.00 and works very well indeed. It's a well built qaulity player. Different models are being closed out at $100 or less.
LED MONITOR - HDMI to DVI-D cable, HDMI media player not working?
By krishn in forum DVB / IPTVReplies: 16Last Post: 25th Feb 2012, 17:20 -
multimedia player connection via hdmi but monitor doesnt have hdmi slot
By ozy666 in forum DVB / IPTVReplies: 1Last Post: 25th Apr 2009, 10:40 -
dvd player hdmi to computer monitor with hdmi
By Kibble in forum DVD & Blu-ray PlayersReplies: 5Last Post: 10th Nov 2008, 13:35 -
upconverter dvd player/recorder recommendations...
By rubberman in forum DVD & Blu-ray RecordersReplies: 0Last Post: 15th Jul 2007, 16:36 -
Using LCD Monitor with DVD Upconverter
By e39mofo in forum DVB / IPTVReplies: 1Last Post: 18th Jun 2007, 14:37
