What are the best settings to do this. the MTS files are from a panasonic SD9 camera an are FULL HD
I Have installed CoreAVC Pro 1.6.5
I Have installed AC3 Filter (stereo 2:1) from K-Lite
I Have the latest version of TMPG Xpress
Please assist because the output files are a bit blocky And I think I can do this much better because the source is full HD
Thanx in Advance
What settings are you using now? Like what resolution/frame size and video bitrate settings.
720x480
bitrate 780KB
audio 128 kb/s
progressive 25fps
insane quality -
Switch to "1 pass quality-based" encoding. Pick the quality (quantizer) you want. The lower the quantizer the higher the quality. Try 3 or 4.
The "insane quality" setting is a waste of time. Balanced will give 95 percent of the quality and take 1/4 the time. "Better" will give 98 percent of the quality and take 1/3 the time. Actually, in 1 pass quality based encoding the quality is the same regardless of the Encoding Mode setting. But the file size gets a little smaller as you go to higher settings. It's when using one of the bitrate modes that the quality changes by a bit. -
worked great altough the quality with insane was insanely good also
Now with the panasonic SD9 you get 5.1 surround sound recordings. But my AC3 Filter is set to stereo... what AC3 setting should I use to get 5.1 surround?
Thanx in Advance
How to merge multiple .mts files (canon HF) into one single .mts file
By frmsuv2van in forum Video ConversionReplies: 15Last Post: 5th Sep 2014, 21:21 -
converting hd (mts) file to final cut express 4
By ang03207 in forum Video ConversionReplies: 3Last Post: 24th Aug 2010, 00:34 -
HD Cam wrote .mts files to my flash card but put in another cam still mts
By Onceler2 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 15th Dec 2009, 06:15 -
lynnfield + tmpg express benchmarks!!!
By deadrats in forum ComputerReplies: 0Last Post: 6th Aug 2009, 20:20 -
AVCHD viceo with .MTS ending cannot be read by Quicktime/ final cut express
By johsch in forum ffmpegX general discussionReplies: 10Last Post: 26th Nov 2008, 14:01
