I have a sony RDR HXD760 that can play DIVX files.
it plays the AVI File fine however on my widescreen tv i have to set it as a 4:3 display to see the avi in the correct aspect ratio with black bars on all 4 sides of the image. I have experimented with changing the Aspect ratio in the AVI file itself but it doesn't change it. I can convert them to DVD format but i want to leave the file as an AVI. Is there any easy quick program that can fix it up for me? or is there something i am missing on my player? the file is a widescreen image for sure.....
thanks for any help or advice you can give.
Werdy666
	What's the actual codec of the AVI? Some players cannot correctly play back XVID or other codecs. You may need to patch the fourcc code to divx from XVID or something. Drop the file into GSPOT and find the exact format of you avi. You are in breach of the forum rules and are being banned. Do not post false information.
 /Moderator John Q. Publik
	looks like its an xvid. so i just need to convert it to a Divx format. ANy programs out there that do just the conversion from xvid to divx?
	What is the resolution frame size of the avi?
 Many players will ignore aspect ratio in avi divx/xvid files so you might need to reconvert to square pixels / 1:1 display aspect ratio, like if you want 4:3 the resolution should be 640x480.
	What happens when you set the DVD player for 16:9 output (which is more normal). Doesn't the AVI pretty much fill the screen left to right and top to bottom with the correct aspect ratio? You shouldn't be seeing an AVI at correct AR with bars on all 4 sides. Does this thing play with correct AR on the computer?...however on my widescreen tv i have to set it as a 4:3 display to see the avi in the correct aspect ratio with black bars on all 4 sides of the image.
	playing on the computer is no problem at all. fills my widescreen monitor fine. On the tv when it is set for 16:9 it stretches the picture horizontally.
	Meaning what? 624x352 is 1.77:1, the same as your TV set. If it's a standard 1:1 AVI, and if it plays on the computer fine, it should also look good on the widescreen TV set, filling the entire screen. Are you saying that when played on the TV it's setting black bars above and below? If so, there's something wrong with the player, the TV, or both, or perhaps with the way you've set them up. 624x352 XviD AVIs play just fine on my widescreen TV set.
  I need to burn avi videos onto a dvd to play on my standalone playerBy -mm- in forum Video ConversionReplies: 10Last Post: 23rd Jun 2012, 16:32
  MKV to AVI to play in standalone DVD playerBy AzzKickr in forum Video ConversionReplies: 8Last Post: 9th Sep 2011, 14:53
  AVI wont play on standalone player, need to convert to whatBy haubmi in forum Video ConversionReplies: 13Last Post: 10th Mar 2009, 14:58
  SUPER - WMV to AVI (Standalone DIVX Player)By psxiso in forum Video ConversionReplies: 2Last Post: 30th May 2007, 10:20
  playing avi file with subtitle in standalone divx playerBy weeleong87 in forum SubtitleReplies: 19Last Post: 16th May 2007, 19:32
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Visit Homepage
				Visit Homepage
