Hi everyone
I have a Philips DVD/Divx player (DVP3146K/98) and it supports (.srt, .smi, .sub, .ssa, .txt) divx subtitles. I'v burned a divx disc with the .avi and the .srt in the same folder and (same name). The video works fine but the subtitle isn't in the language i want (Arabic), It's has mixed letters and characters between latin, chinese, trees and squares.![]()
I switched between the region codes but the problem stills. My question is: Did i miss a step in the burning stage, like i had to modify something in the .srt file.
please help
It maybe doesn't support arabic characters. You could try make a divx with image subtitles using sub2divx or AVIAddXSubs.
Baldrick is probably right. Philips DVD players support Latin and Cyrillic character sets for Divx subtitles and that is all. I am not aware of any exceptions.
We get posts here all the time from guys who want to see Divx with Arabic subtitles and can't find a player that supports it. I don't think there is going to be a solution for you except to encode your files with what we call "hard subtitles' where they are part of the video image. -
jman98, there is no need to re-encode the video and make hard subs. The solution suggested by Baldrick is lossless, way easier and faster; xsub is the most appropriate format for stand-alone players. I use AVIAddXSubs which has never disappointed me, it is an excellent tool.
Problem -Subtitling using Subtitle Creator DVD from Multi Volume DIVX Movie
By shotokan101 in forum SubtitleReplies: 0Last Post: 4th Jan 2009, 11:43 -
Philips DCP850 DivX overall quality (and DivX subtitle handling) question!
By mabhz in forum DVD & Blu-ray PlayersReplies: 0Last Post: 3rd Jul 2008, 19:59 -
Divx subtitle on DVD/Divx player Problem
By abo_shreek11 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 8th Mar 2008, 04:41 -
Help Friend! How to read subtitle file on my dvd player (not divx supported
By justin1983 in forum SubtitleReplies: 17Last Post: 26th Jan 2008, 12:42 -
playing avi file with subtitle in standalone divx player
By weeleong87 in forum SubtitleReplies: 19Last Post: 16th May 2007, 19:32
