Hi,
sometimes I want to compress some dvd that have several films, or documentarys or short films.
Dvdrebuilder Pro takes always the longest one as the feature and then you can not redistribute well the bitrate among all of them.
Is there a way to change this, or at least to choose oneself whic pgc is the feature?
Thank you in advance.
P.S. I remember I could do that with Reauthorist, but that program only worked with the big three, and besides now I prefer DVDRebuilder Pro
The thing is in that cases I never select "Steal space from extras" and dvdrebuilder always choose a main feature.
It's not really a big issue, but it would be great to have the control of that.
For instance, I want to compress now a dvd with two features: the duration of the first one is 1.29 and of the second one is 1.31, and I want to let untouched the first one and compress only the second one, but it's not so easy because ir's just this second one the one dvdrebuilder choose as feature and allocates to it automatically all the saved space.
Anyway I know it's not so usual to have different feautres in a dvd, I'm only saying it would be good to allocate the space oneself and give that saved space not just to one stream. -
You can always adjust the bitrate anyway you like using the segment viewer after the prepare stage. Use 3 click mode.
VLC Player's "record" feature- can I change the output folder?
By gastrof in forum Newbie / General discussionsReplies: 1Last Post: 29th Mar 2012, 23:32 -
Leave Menu, Change Main Feature
By Mukenio in forum Newbie / General discussionsReplies: 10Last Post: 4th Jun 2009, 22:29 -
aspect-ratio change feature?
By tff in forum Authoring (DVD)Replies: 9Last Post: 30th Jan 2008, 00:42 -
DVDRebuilder
By santino_avi in forum DVD RippingReplies: 5Last Post: 20th Jan 2008, 15:03 -
Please suggest which is better DVDShrink or DVDRebuilder?
By leinan in forum Newbie / General discussionsReplies: 4Last Post: 12th Jul 2007, 21:00
