I recently went through the steps outlined in the how-to's to convert from avi - dvd w/ subtitles and after the encoding I was left with no audio or subtitles.
Has anyone else run into this?
This can happen, for example, if your audio is encoded in a form for which a codec is not installed. Take a look at the Progress logfile (click on the "i") to see what ffmpegx might be complaining about.
As to subtitles, what format are ypur subs in?
I redid the encoding and everything seemed fine. However, when I try to play it in my dvd player, suddenly the audio doesn't match the video unless I speed it up to 1.2x. Doesn't make any sense to me.
Furthermore I tried it in a different player and audio and video seem to match most of the time.
Is there a simple fix to this? Does it have something to do with the framerate setting?
How to make audio / video business card and website audio/videos clips
By tmh in forum Newbie / General discussionsReplies: 6Last Post: 4th May 2011, 11:25 -
Will Sony Vegas work with a high end audio interface used for digital audio
By fuzzblaster in forum AudioReplies: 3Last Post: 1st Sep 2010, 17:24 -
removing the commentary audio track from an AVI file with mpeg layer3 audio
By wildrthanevr in forum AudioReplies: 1Last Post: 10th Mar 2009, 01:29 -
Easy DVD to MP4/MKV with Dual Audio, 'soft' Subtitles, and 5.1 Audio?
By Grovest in forum DVD RippingReplies: 4Last Post: 3rd Nov 2008, 04:12 -
demux audio from avi then two audio sources(aac 2ch + ac3 6ch)
By fatcat23 in forum ffmpegX general discussionReplies: 4Last Post: 21st Sep 2008, 01:19
