Results 1 to 9 of 9
    Feb 2007
    before i research this issue i would like to know if its even possible.ok,lets say you go vhs to dvd with a combo machine.you rip the video content of the dvd to the hard drive in whatever form.now youve got a copy of the video from a vcr on your comp.is there any way to restore or clean up the video from that point?
  2. Member zoobie's Avatar
    Feb 2005
    Florida
    yep...several filters can be applied to suit your taste with virtual dub
    the VHS filter for one
    Feb 2007
  4. Mod Neophyte redwudz's Avatar
    USA
    If this is just hypothetical, you will have problems with a commercial VHS tape using a combo VHS>DVD machine. It will likely not copy the tape because of Macrovision encryption.
    With a tape without Macrovision, yes, you should be able to copy it. VirtualDub is a good program, but your DVD video will be in MPEG format. You can extract it to a single MPEG file with VOB2MPG. The newest VD or VD Mod will accept MPEG, but only output AVI type formats. So, after filtering. you will have to convert it back to MPEG format if you wanted a DVD format for the final version. The more conversions you do, the more quality losses. Something to consider.
    Any time you filter, you will have to re-encode. With VD or VDM, you could frameserve the filtered video directly to a MPEG encoder and avoid some losses. At least simpler than creating a in-between file. Look to: https://www.videohelp.com/virtualdubframeserve.htm
    VirtualDub has a lot of filters available. Some here: http://www.thedeemon.com/VirtualDubFilters/
    I know, a lot to consider.
    Feb 2007
    i just came across Virtualdub-MPEG2 and it will import the files virtualdub would not.i forget sometimes that virtual dub can do pretty much anything cuz it wont always load the files im working with and havent used it in a while.but thanks for the suggestion.got a link the particular vhs filter?
    Feb 2007
    yea the overdub syndrome carries over,sad.what what ive seen so far the filters may "improve" the picture but only slightly or to a certain point.the quality is still dependent on the vhs sorce.your not going to convert old vhs to dvd quality but you can smooth it out a little.
    Feb 2007
    i hope im right about this before i settle on doing without really knowing.i spent about 10hrs experimenting with different filters and settings.and so far i can only see subtle improvements in the overall picture quality.going from vhs to dvd is a big project and i would like to do it right.can anyone confirm the facts?can virtualdub convert vhs footage to dvd quality or is it more in taking out the flaws and such? 8)
  8. Member classfour's Avatar
    The Heartland, United States
    Depends on source quality.
    Depends on original VHS player.
    Crap in = Crap OUT
    ;/ l ,[____], Its a Jeep thing,
    l---L---o||||||o- you wouldn't understand.
    (.)_) (.)_)-----)_) "Only In A Jeep"
    Feb 2007
    blunt & to the point.so,i think it answers my question.thanks
