    Mar 2008
    Hi,
    I am sure this is a stupid question, but here goes...
    I want to use iMovie/iDVD ('08) to create a video with a widescreen aspect ratio (16:9), but the footage was shot with a 4:3 aspect ratio. So I set the aspect ratio in project properties to the widescreen option. However, after burning the DVD and playing on a TV the shot is full screen. Also, if I choose a "widescreen" menu in iDVD part of that menu is chopped when played on TV. Any suggestions? Thanks in advance for the help!
    -Johnny
    PS - If this issue has already been addressed, just let me know and I will do a more thorough search!
  2. Hi
    if the footage is 4:3, why do you want to display it as 16:9?
    (I suppose on a 4:3 tv?)
    use mydvdedit (double-click on an .IFO files to open it):
    - select your VTS (top/left) = your video (eg: "VTS 1")
    - (middle /center) you'll find 3 vertical "buttons" (I don't know the english word). Last is "DVD", middle is "VTS x". Click on "VTS x"
    - select the display(you certainly want an "16:9 auto Panscan & Letterbox" = widescreen)
    so iDVD tagged your video as "16:9 auto Panscan & Letterbox"
    I don't understand your problem, you wanted Letterbox only? If so, just check the settings of your DVDPlayer ("16:9 auto Panscan & Letterbox" displays as Letterbox OR PanScan depending on the user settings - aka the DVDPlayer settings)
    bye
    For DVD, iPad, HD, connected TV, … iMovie & FCPX? MovieConverter-Studio 3 (01/24/2015) - Handle your camcorder's videos? even in 60p or 60i? do a slow-motion? MovieCam.
    Mar 2008
    I will try your suggestions and let you know the results soon.
    Thanks for the advice.
  4. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Here is how the pros do it. What is your creative idea?
    You can crop in but unless you shot loose you will be chopping heads and reducing quality.
    http://www.kiva.org/about
  5. PS: I'm not sure my answer was the good one.
    If your shoots were 4:3, you will just deform the display, your tv is a 4:3 format or not? (you didn't provide enough informations...)
    bye
