I'm trying to convert a few mkv files to MP4 so I can watch them on my PSP using ffmpegX.
The problem I'm having is that I can't figure out how to add the subtitles to the conversion. The mkv itself contains two audio tracks and two subtitle tracks (Japanese and English).
Change the audio track is easy as there's a drop down list I can select the track from but it seems the only way to add subtitles to the conversion is if I have an external file.
Is there no way to just use the subtitles that are built into the mkv?
"Hey, it compiles! Ship it!"
I managed to extract the subtitles using the mkvtoolnix tools.
You can do "mkvmerge -i file.mkv" to list all the tracks that are contained within the mkv file which gives you an output like this:
File ’file.mkv’: container: Matroska
Track ID 1: video (V_MS/VFW/FOURCC, DIV3)
Track ID 2: audio (A_MPEG/L3)
Track ID 3: audio (A_VORBIS)
Track ID 4: subtitles (S_TEXT/UTF8)
Track ID 5: subtitles (S_TEXT/UTF8)
Then you can do "mkvextract tracks file.mkv 4
ubtitles.srt" to extract the subtitles.
I did this to extract the subtitles and when I open up the .srt file in a text editor it looks fine. However, when I try and load these subs into ffmpegx and encode no subtitles appear on the video so I have no idea what I'm doing wrong.
Anyone have any idea?"Hey, it compiles! Ship it!"
Burning the subtitles onto the video with ffmpegX is a mplayer/mencoder feature. The PSP presets do not use mplayer/mencoder.
You would be better off trying to do it with Perian and Decoding with QuickTime.
How to Convert MKV with ASS Subtitles to DVD - Solved!
By rickydavao in forum Video ConversionReplies: 10Last Post: 22nd Nov 2010, 20:51 -
Not sure if it goes here. Convert MP4 and MKV to DVD with subtitles.
By The_Forastero in forum Video ConversionReplies: 2Last Post: 15th Jun 2010, 13:33 -
convert mkv with subtitles to ps3
By karatechop in forum SubtitleReplies: 1Last Post: 30th Dec 2009, 06:29 -
Convert from MKV and keep subtitles / audio.
By Alchey in forum Video ConversionReplies: 1Last Post: 10th Oct 2009, 02:45 -
convert mkv to dvd with subtitles
By Anonymous43453 in forum Video ConversionReplies: 10Last Post: 10th Jul 2007, 19:04
