  1. I have a number of TS files which contain DTS audio. DTS audio isn't supported for streaming to a PS3 so I've demuxed the TS file using ProjectX. I then converted the DTS audio to AC3 (using eac3to) and then muxed the M2V and AC3 together using tsMuxeR. I then converted this to a Program Stream (mpg) using HDTVtoMPEG2.
    What I'm now finding is that these files are shown as having no duration.
    How do I fix this? What could be the cause?
    Thanks.
    Try multiplex the m2v and ac3 directly to mpg with imagompeg-muxer or tmpgenc (file->Mpeg tools->simple multiplexer).
    What video player are you testing with?
  3. Banned
    Jun 2007
    UNREACHABLE
    As Baldrick said, you can go directly from M2V to MPG ---
    no need for an intermediate TS.
  4. Thanks I'll give them a go.
    I'm streaming to my PS3 with WMP11.
