Hi ..
I've a couple of questions about some audio things ..
1- I have a video with 2 audio streams , how can I separate each ( audio 1 in a separated audio file , audio 2 in a separated audio file , and the video in a separated video file ) . If you can , I need the program that can do such thing , and the way of doin' it if it's possible .
2- You all know that if I wanna make an audio CD it is limited in only 1 hour , more or less . How can I make an audio CD with 2 , 3 hours or longer .If you can , I need the program that can do such thing , and the way of doin' it if it's possible .
see ya .
Hi..
1- If we know what format you video have we can tell you more precise what to do and
what program to use.
If its xvid, divx video and mp3, ogg, ac3 mpa audio in a avi, mkv, mp4, ogm container
you can use VirtualdubMOD.
If its a vob file (DVD) you can demux (split) the file with projectx, pgcdemux and some other programs.
2- If you want to make an audio CD longer than 1h you must convert the music tracks to mp3 format.
This will not be a standard Audio CD so the CD player must be abel to play mp3 files. Most DVD players
can do this and some car stereo players. A good CD ripper and audio converter is Cdex dont go below 192kps.
Another fine format is FLAC its lossless and can compress the tracks to 1/3 of original size. But its often only
computers that can play this format a fin mediaplayer is Foobar2000.
stars.... -
You CANNOT make a true audio CD (I am NOT talking about just burning MP3 files to disc, but making a true audio CD compatible with any audio CD player) any longer than the disc allows. 80 minute CD-Rs allow 80 minutes. That's it.
If you can find them, you can buy 90 or 99 minute CD-Rs and burn them. However, these discs do not follow CD standards and all burners can't burn them correctly. I have used the 90 minute CD-Rs for audio CD and they work fine for me.
You will have to have a DVD player that supports VCD or a VCD player,
but there is a program called Audio2VCD at http://www.vcdeasy.org that can put 3+ hours of audio in VCD format on a single CD-R disc. Note that this is a VCD disc you create and NOT an audio CD. Otherwise, stars' suggestions are also possible. -
Actually one can write over 7 hours of stereo audio onto a VCD
if one feels satisfied with MP2 @ 224kbps.
Hi ,,
mmm , I see . no matter , I'll just stick to the rules and use 80 minutes CD
. and about the dumuxing job , I only need one of the audio streams separates , so I think dvdlab pro would do the job , wouldn't ?
see ya. -
I'd rather have MP2 than MP3 at that value. You may not know this, but MP2 is actually more true to the original source at high bit rates than MP3. MP3 wasn't invented because MP2 sucks. It was invented because MP2 was actually too good - it didn't compress enough. MP3 may arguably be better than MP2 at lower bit rates in terms of file sizes and quality, but MP2 shines at high rates. A VCD using 224 Kbps MP2 audio would not be bad at all.Originally Posted by Midzuki
Couple of Questions re footage.
By Lensmeister in forum Newbie / General discussionsReplies: 2Last Post: 17th Feb 2012, 17:44 -
A couple of questions for the experts?
By Rumdaddy in forum Newbie / General discussionsReplies: 6Last Post: 22nd Sep 2011, 13:54 -
a couple of 1080i questions
By deadrats in forum Video ConversionReplies: 14Last Post: 29th Aug 2009, 21:11 -
a couple of sub questions
By Kanyeeeze in forum SubtitleReplies: 1Last Post: 1st May 2008, 18:03 -
couple questions
By mainegate in forum ffmpegX general discussionReplies: 2Last Post: 31st Aug 2007, 12:22
