anyone tried to rip Blu-Ray disc Hitman?
I cant yet get my rip to it to play.
excuse my ingles, i speak french
thanks
Results 1 to 9 of 9
rhegedus is probably right. If Hitman uses the new BD+ encryption, you will have problems. No one has been able to convert a disc with BD+ to any other format. Some BD+ discs can be ripped, but the files may not play correctly. You may need a new version of your ripping program, but you may still have problems.
i still havent got it runnin as of yet. tried PDVD 3310a, no dice.
any help would be kind -
rip it with the latest any dvd,set the region to remove manually and set it to remove BD+ and you should be ok,if it still gives you trouble try running the largest mts file through Tsremux selecting the video and the audio you want to keep and output as Blu ray.
I'm using powerdvd 3730 and it plays fine from the disk
(region a) or if i rip it but 3.10 to yuma (region b)came out with audio and no picture (just funny lines and colours)I opened it in nero 8 (you need the bluray plugin)and it works fine,alot of the time it seems the problems are with powerdvd its incapable of navigating the menu on the uk disk and cyberlink support just send you round in circles.
Blu Ray and burning a Data Disc...not a Video Disc
By Moontrash in forum DVD & Blu-ray WritersReplies: 16Last Post: 16th Dec 2019, 22:18 -
Copping Disc - Disc Data Recovery Software.
By Teac23 in forum DVD RippingReplies: 5Last Post: 1st Oct 2010, 20:06 -
Hitman rip, repeated scene
By jntaylor63 in forum DVD RippingReplies: 7Last Post: 17th Dec 2008, 07:13 -
cant bypass HitMan BD with AnyDVD 6.4.0.0!
By nightshade11 in forum Blu-ray RippingReplies: 4Last Post: 21st Mar 2008, 08:53 -
hitman blu ray disc?
By bimboppin in forum Video ConversionReplies: 1Last Post: 7th Mar 2008, 10:22
