In which forum can I ask about the possibilities/capabilities of my PVR as it applies to connecting an external HD, etc??
Beaker14
"DVD Recorders" would be a good place as it also covers Tivo-type devices that are HD based. Good question and good for you for posting in General Discussions first, which is the right thing to do.
Unless someone is familiar with your make and model (you didn't note which you have), the only way to know for sure is by trying. Many DVR's have the external (USB/Firewire) ports disabled. There is also the question of what exactly you are trying to do. Most DVR's won't playback files from an external drive and the few that do, typically treat the external drive as an addition to the internal drive and will only playback files that it placed on the drive.
Google is your Friend -
If this is a cable company DVR, they usually support external drives off a SATA port and use encryption. It is up to the local cable company to turn this feature on or off. Most have it set to off.
http://www.kiva.org/about
Hd pvr help!!
By iSkaternick in forum Capturing and VCRReplies: 2Last Post: 6th Jan 2012, 09:41 -
Need help with my hd pvr
By Denko in forum Capturing and VCRReplies: 0Last Post: 26th Oct 2011, 16:05 -
PVR files on a PVR formatted disk
By keithy in forum Newbie / General discussionsReplies: 2Last Post: 22nd Apr 2009, 09:26 -
dvd player +dvix+usb with external 160GB external HD problem...
By spidermen in forum Newbie / General discussionsReplies: 14Last Post: 14th Oct 2008, 20:45 -
Hauppauge PVR-350 vs PVR-500MCE
By dphirschler in forum Capturing and VCRReplies: 1Last Post: 11th Mar 2008, 10:04
