    Mar 2008
    how to convert pal avi to ntsc avi ?[/list][/list]
    Apr 2004
    Miskatonic U
    What do you want to do with it ?
    If it is for DVD, resize to 720 x 480, encode at 25 fps, then use DGPulldown to make your player play it back at 29.970 fps, just like an NTSC disc. This approach keeps the audio in sync without having to alter the running time.
    Read my blog here.
    Mar 2008
    thank you, not sure i know how to pull that off.
    Apr 2004
    Miskatonic U
    FAVC can automate this process, if you want a DVD at the end of it.
    Read my blog here.
  5. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    How will the files be used? If you are only using them on the PC, there is no need to convert anything.
    Google is your Friend
