Your words are not quite correct. the correct verbage would be "the outcome you are getting makes no sense to me"
since my words are pretty simple and clearhehe
yes 3.2 latest version. My backup window appears identical to yours.
I am trying a smaller than 1gb file to see what happens.
Results 31 to 42 of 42
Hmmm now this is interesting. Tried a 586mb file and it made an ISO
but I now realize this is not relevant since I now told it to make a 4gb iso and ITS MAKING IT AN ISO not an I00 I01 Very intriguing. I have never tried this on the home computer which means "something" on the other computers is causing it to split the file into I00 I01 etc
I am going to put this copy of shrink on a disk and bring it with me and compare it to the version on the other computer and see if its any different somehow. (they both say 3.2 but maybe its a slight variation of 3.2 ??)
Very freaky. There must be some setting somewhere in shrink that causes it to split the file up. I already tried to use 1gb vobs check box and it had no effect. There must be some setting somewhere else that causes this. -
I am just a worthless liar,
I am just an imbecil -
also, the box that says "split vobs into 1 gig chunks" SHOULD BE CHECKED! that is something different...
I figured that was unrelated but I tried it anyway just in case as expected it made no difference in the iso file.
so on the PC with a FAT32 drive dvdshrink split the output file, but on your PC at home it did not? perhaps it is part of dvdshrink's programming to automatically split the file if it is being written to a FAT32 file system?
Not sure. The primary drive on both machines is NTFS the thumb drive I am writing to on both machines is FAT32 and in theory its the exact same copy of Shrink on both machines and the exact same copy of windows XP SP2 on both machines (I will confirm that tomorrow) So my first assumption is there is some sort of "setting" somewhere.
Does shrink have any dependencies on other programs besides windows? -
so you're saying you have 2 computers setup the same, both writing to a FAT32 drive, but you are getting different results on each? well crap, i'm afraid i'm running out of ideas now..
no not as far as i know.Does shrink have any dependencies on other programs besides windows?I am just a worthless liar,
negative. I had ASSUMED both flash drives were fat32 (since windows will not permit you to format NTFS to a flash drive)
the flash drive I tossed in at home "happened" to be my test case of using third party software to format a flash drive NTFS
once I saw this I realized what had happened. SO it seems shrink is hard coded for some reason to ONLY allow "split iso" on fat 32 partitions even if the total file is less than 4gb (kind of logical actually since its usually making the final project 4464mb and he probably just never though someone would make or need smaller etc..)
I had never TRIED to do it to the hard disk before getting home since I did not need the iso on the hard disk.
now i know to get shrink to make an actual single file iso I have to make the target drive a NTFS partition. No big deal.
Using DVD Decrypter should I use .ISO or .IFO file !
By augustya in forum DVD RippingReplies: 21Last Post: 29th Mar 2012, 12:44 -
Using DVDFab to make ISO file from BD?
By neworldman in forum Blu-ray RippingReplies: 1Last Post: 5th Apr 2010, 06:40 -
DVDFab HD Decrypter: no ISO created!
By taboo in forum DVD RippingReplies: 8Last Post: 5th Apr 2009, 23:25 -
DVDFab HD Decrypter New version 4.0.0.8 Beta file corrupted?
By Anonymous4374945 in forum Newbie / General discussionsReplies: 3Last Post: 7th Nov 2007, 09:46 -
DVDFab HD Decrypter and BD iso
By rhegedus in forum DVD RippingReplies: 5Last Post: 13th Oct 2007, 06:13
hehe
