Hello there!
i'm going mad!! I want to put my own mix(made in cool edit pro) on SVCD with PROLOGIC sound.. That must be possible!?? How do i encode my 4 monowaves to PROLOGIC?? I know its a longshot but maybe someone has the same problem....
Regards /Daniel
Prologic is a decoding method not an encoding method. It is impossible to encode a prologic audio stream.
A prologic receiver will decode any stereo source into prologic. I'm sure there are methods to encode a stereo audio stream in such a way that it is more condusive to prologic decoding but I don't know how. Hopefully someone else can give you some pointers. -
In my mind you cant decode without encode.. Maybe a proLogic reciever can play any stereosource in "ProLogic" but there MUST be some difference in the result in how you Mix it... I know that you should do this:
Put left channel 100% Left
Put right channel 100% Right
put center in middle
make surroundchannel by "invert "the phase of a mono track..
IF you downmix these 4 ch to stereo, you should have a stereotrack including ProLogic sound BUT i cant get it to work
anyone?? -
What you are describing is dolby surround sound, which is an encoding method. As I said before, Dolby Prologic is a decoding method. You do not encode the center and surround channels, they are derived from the left and right channels. All you need, and in fact all you can do is encode your left and right channels and the decoder does the rest.
Downmixing is only required for dolby surround. Someone posted an explaination of how to manually downmix into dolby surround. Do a forum search on it and you should be able to find it. -
hi,
as far as i know DOLBY PROLOGIC is a Method used to separate any sound in put based on the frequency of the sound into front/center and rear channel out put. You can see this for ecample get a old vedio tape with no dolby or any sound effect and use dolby prologic to paly the sound on the reciver you will know what it does. Hope this helps
Baskaran :lol:
Selecting passthru audio in MPC HC rather than the prologic
By skinney6 in forum AudioReplies: 2Last Post: 26th Jan 2012, 11:37 -
Dolby ProLogic in PHILIPS
By anirban in forum DVD & Blu-ray PlayersReplies: 4Last Post: 16th Oct 2008, 16:09 -
Dolby Prologic IIx. I understood that it will "create" a surround
By andrema71 in forum AudioReplies: 3Last Post: 6th Jun 2008, 10:22 -
ac3filter - back speakers no longer working for Prologic output
By pglenn in forum AudioReplies: 0Last Post: 6th Nov 2007, 23:09 -
Help with PAL SVCD to NTSC SVCD
By silentmonolith in forum Newbie / General discussionsReplies: 4Last Post: 6th Jul 2007, 06:18
