Hello Group, I received a Viewsonic LCD monitor - model vg2230wm and it has an optimum screen resolution of
1680 by 1050. Can anyone recommend a graphics card for this monitor as my 12 year old Matrox cards are
too old for this monitor.
Thanks to all that reply.
tug_hill2
Reach for the Starz
Depends on the motherboard - AGP vs PCI-e . If you're not doing any gaming, anything above an Nvidia 6200 will work. I like video cards that don't need fans -
http://c1.neweggimages.com/NeweggImage/productimage/14-127-316-03.jpg
The DVI input is cleaner and nicer looking. Did your monitor come with a DVI cable? -
Pretty much any video card currently on the market will likely work without any issues. Typcially all that is required is the latest drivers to provide support for WS monitors. In your case, you are likely using an old PCI card with like 8MB of RAM. You will likely have issues finding any PCI cards which use chipsets (and drivers) new enough to support WS resolutions.
Google is your Friend -
Before any card might be suggested, you need to know more about what the motherboard was designed to support , and if agp is available
There are AGP cards with older 2x and 4x support still available
5200 and 5500 (better) both nvidia
9200 from ati
Pci is still available should it be the only option
Do I need a new graphics driver for this newly-connected monitor?
By jeanpave in forum ComputerReplies: 6Last Post: 3rd Dec 2011, 04:08 -
Very Weird issue with Capture Card and Graphics Card? Please help
By Ps3riiper in forum ComputerReplies: 9Last Post: 11th May 2011, 15:51 -
Getting the BEST out of my Graphics Card and Monitor
By SE14man in forum Newbie / General discussionsReplies: 3Last Post: 27th Dec 2010, 08:42 -
Selecting the right DVI / HDMI cables for a Graphics card and Monitor
By vhelp in forum ComputerReplies: 11Last Post: 9th Nov 2008, 07:34 -
Monitor / Display Resets - Dying Graphics Card?
By daamon in forum ComputerReplies: 15Last Post: 17th Jun 2007, 03:41
