Hi I have a 720p MKV file and I have been trying to convert it into an mpeg4 file so it will play on my xbox360 in true HD. If you dont know the xbox 360 can now play xvid files such as the ones labbeled hdtv and hr.hdtv but of course both of these are not true HD. What Im trying to do is convert the 720p MKV file into an xvid file that will play on the 360 however I want the resolution of 1280.720 to remain untouched. Now I tried River Past Video Cleaner Pro and also just recently tried avidemux, but no luck. In avidemux I selected the output option and I changed the conversion settings to
-Video: MPEG4 ASP (xvid4) [I altered the xvid encoding type to the same quantizer as input]
-Audio: MP3 LAME [I'm not sure if the 360 will play a better audio quality I wanted to get the best 5.1 encoding]
-Format: AVI [The MP4 option is also available but I thought the hdtv and hr.hdtv files are avi so I should use AVI]
When the avidemux is done converting one episode (1.07Gb, 3 - 4.5hrs) it ends up being 1.79Gb and looks like a blank generic file. It wont play unless you right click and open with a media player and when I try it in my 360 it doesnt recognize it as an Xvid file. I dont know what I did wrong and can use a hand to get this working. Also does anyone know if the toshiba hd-a30 hddvd player plays mkv files through the usb port or even xvid files.
Read my blog here.
Are you kidding me, thats it? lol Well it looks like it might work, it put up a thumbnail automatically. Thanks for the help.
damn I was sure that would be it guess I was wrong. I added .avi but when burned to a disc and played on my 360 it still can't play the video. It recognizes it as an avi however, what can I do? has anyone used a program for this purpose and got it to work with HD quality on their game console.
" Who needs Google, my wife knows everything"
Thanks, ill try it but I might be out of HDD space after downloading all of those required programs haha.
As for
only VideoInspector, MeGUI and VirtualDubMod are not
strictly necessary for the task.
How to play MKV, MKV to AVI, MKV to DVD, MKV to Xbox 360 or Playstation 3
By Baldrick in forum Video ConversionReplies: 2Last Post: 8th Mar 2012, 03:45 -
The Best Xbox 360 and PS3 mkv video converting to mp4 App.
By spyder7777 in forum Newbie / General discussionsReplies: 0Last Post: 11th Apr 2009, 05:55 -
Xbox 360 no longer plays mpg?
By David97 in forum Video Streaming DownloadingReplies: 4Last Post: 15th Dec 2008, 08:01 -
MKV to Xbox 360 compatible file?
By nfl2k2 in forum Newbie / General discussionsReplies: 5Last Post: 26th Aug 2008, 20:38 -
MKV to Xbox 360
By dbanga in forum Newbie / General discussionsReplies: 1Last Post: 16th Aug 2008, 09:32
