    Mar 2007
    China
    we know that a encoder based on MPEG compressing technology requires that video frame's pixel number should be integer times of 16. For example a 480X272 video frame, both 480 and 272 are integer times of 16.
    for vegas 7 and previous version, for a 480X270 project ( a 16:9 project), if I want to render the video using mp4 or 264 encoder, even I set the frame to 480X270 in the encoder's setting tab, the encoder will change the frame to 480X272. I thought I knew why, since it's a MPEG encoder.
    but waite, now the same project in VEGAS 8, render using mp4 or 264 encoder, if I set the output frame to 480X270 in the encoder, the encoder will not change it. the rendered video is definitely 480X270! I have cheked it using Gspot.
    then why? how can this happen? does VEGAS 8 have another advanced encoder? or the MPEG compressing standard has changed or improved?
    thanks.
    Oct 2005
    666th portal
    i'm not sure it was ever an ieee requirement to be based that way but an encoder adjustment so no part of the video wasn't compressed/motion compensated. try comparing the sizes of a 270 vs 272 encodes and i'll bet the 270 is bigger because of the "non-standard" size.
    mpeg4 simple profile is 16x16 based but other profiles allow down to 4x4 macroblocks requiring higher bitrates.
    Mar 2007
    China
    thanks for reply. I'm afraid that's not the cause.
    even 270 is not integer times of 4.
  4. Banned
    Jun 2007
    UNREACHABLE
    Depending on the codec (and depending on the application that uses it),
    only the width must be an integer multiple of 4, whereas the height
    must be just a multiple of 2.
