I mean your system when encoding?
I just set up a 1gig duron and My idle temps is about 37-40 and under heavy encoding I jump up to between 45-47 degrees..
I thought that was sorta high.. hows everyones temps run?
47-50C on both processors during encoding, and I have a very well-cooled case (9 case fans in addition to the heatsinks on the processors).
45-47 is not high at all. I don't know about Durons, but Athlon XP's can run fine until they hit the 75-90 range. -
tinycorkscrew, okay I just have to ask why the hell do you have 9 case fans?
jasond, the temp is fine for your duron. Now if you get up around 60c then you might want to worry. -
Why 9 fans?
Lots of hard drives. I have a modified Addtronics W8500 case, and it can hold as many as ten hard drives, though I don't usually have that many installed at once.
The fans are positioned 1 on the side, 4 in front, 4 in back. The airflow is pretty good. -
i run distributed.net 24/7 so my cpu is always under 100% load... my cpu temp is around 45-47 celcius... this is with a alpha hsf...
one thing i discoved when my temps were rising about 2 degrees a week, it got up to a max of 69 before i got scared and started guttin my comp... my heatsink gradually filled up with dust... all the fins on it had dust bunnys in them... i blew all the shit out of it and it ran at 45 degrees!
Want to create Really Cool DVD's ???
By Deter in forum Authoring (DVD)Replies: 40Last Post: 4th Jan 2010, 23:34 -
Cool nostalgic site - retroland.com
By Tearren in forum Off topicReplies: 10Last Post: 19th Mar 2009, 03:32 -
Cool Edit Pro 1.2a
By rixware in forum AudioReplies: 15Last Post: 14th Feb 2009, 18:07 -
How do you keep your computer cool in the hot months?
By yoda313 in forum PollsReplies: 44Last Post: 20th Jul 2008, 07:21 -
I just listened to my first podcast - cool!
By yoda313 in forum Off topicReplies: 3Last Post: 26th Sep 2007, 16:17
